D16z6 swap almost done
Hey guys, ive got my motor ready to drop into my 91 civic cx, im doin a complete dpfi automatic, to a mpfi (WITH VTEC
) standard.... just a couple things i need to know first..
1. I will be going to an obd1 distributor and 4 wire o2 sensor, will the obd0-0bd1 conversion harness have the nessesary wires to run to this destributor and o2 sensor?
2.Will all the plugs for the engine sensor fit, or should i go get a harness from a 92-95 and chop that up for plugs?
and finally
3. I have to do the mpfi conversion, does the ecu supply each injector with the right voltage or am i going to still need the resistor box (just trying to save myself a couple steps on the conversion if i can?
i know thats a lot of questions but i searched the web and i cant come up with a definate answer
Thanks guys!!
) standard.... just a couple things i need to know first..1. I will be going to an obd1 distributor and 4 wire o2 sensor, will the obd0-0bd1 conversion harness have the nessesary wires to run to this destributor and o2 sensor?
and finally
Thanks guys!!
