leaking oil from somewhere...
Old Oct 19, 2004 | 12:40 PM
Can't Catch Me's Avatar
Default leaking oil from somewhere...
i just spoke to my brother today...he's having problems with his prelude...here's what he said...
he said that the engine's losing oil from somewhere but he can't figure out from where...he checked the oil pan but it's higher than that...he checked the valve cover but it's lower than that...he checked the oil filter area but it's not there either...
he just had to put another half a quart today...and it's definitely not burning oil...it's a 1997 Honda Prelude Base (h22a4) with the Steptronic transmission (auto)...
i'm guessing you guys would have a good idea of where to begin diagnosing the problem...any help would be much appreciated...thanks.
Old Oct 19, 2004 | 12:44 PM
fastprelude60657's Avatar
cam seal is a comon problum with the h22 so look there!
Old Oct 19, 2004 | 01:02 PM
99_SH's Avatar
Default Re: leaking oil from somewhere... (Can't Catch Me)
The motor is prolly burning the oil. If you think its a leak, you could use a dye and try to find it.
Old Oct 19, 2004 | 01:44 PM
Carbon_Lude98's Avatar
Default Re: leaking oil from somewhere... (99_SH)
mine burns about 1 quart every 1500 miles, if he gets on it alot its gonna burn.
but look into the cam seal.
Old Oct 19, 2004 | 01:56 PM
flyrod's Avatar
Default Re: leaking oil from somewhere... (Carbon_Lude98)
There was a recall on the front balancer oil seal. This could be something to check. Sounds like it is big enough that it shouldn't be too hard to find. Clean off then engine, start it up and see where the oil firs appears. Good luck...
Old Oct 19, 2004 | 03:50 PM
killa_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Can’t Catch Me &raquo;</TD></TR><TR><TD CLASS="quote">i just spoke to my brother today...he's having problems with his prelude...here's what he said...
check the oil filter. The filter may have a bad seal.
i'm guessing you guys would have a good idea of where to begin diagnosing the problem...any help would be much appreciated...thanks.</TD></TR></TABLE>
Old Oct 19, 2004 | 03:51 PM
killa_lude's Avatar
Old Oct 19, 2004 | 05:19 PM
SuperSlow's Avatar
If you don't see puddles or drips on the pavement where you park, then it is just normal h22 oil-eating. I usually add about a quart every 1500 miles.
Old Oct 19, 2004 | 05:44 PM
M-unit's Avatar
Default Re: leaking oil from somewhere... (SuperSlow)
how common is this slow oil loss thing. I dont lose any or not enough to notice. 97 sh, and yeh i get on it every few days
Old Oct 19, 2004 | 07:08 PM
Default Re: leaking oil from somewhere... (M-unit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M-unit &raquo;</TD></TR><TR><TD CLASS="quote">how common is this slow oil loss thing. I dont lose any or not enough to notice. 97 sh, and yeh i get on it every few days</TD></TR></TABLE>
i have heard of alot of the dohc vtec's burn oil not just the h22. but ive posted this same question and i think i got about 10 guys telling me that it was common. so i quit worrieing about it. now i just add a quart every 1500 and check it every now and then. but i think its fairly common.
Old Oct 19, 2004 | 09:30 PM
the thing with this is, when i first got the car i took it to honda to do their 75 point inspection and they noted that there was an oil leak. so i'm pretty sure it's leaking somewhere. i'm positive it's not burning oil. i'll check the cam seal. how do i get to that?
98prelude1
Jan 29, 2008 05:56 AM
roadrunner1
Mar 3, 2007 05:34 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
T25So
Mar 22, 2004 08:23 PM
deepnite
Oct 9, 2002 01:46 PM
