Any ideal what would happen if...
Got a question the service manual for 5th Generation prelude says i should get my timing belt checked at 168,000 K's
I called honda they said that should be about the right time to change. What is the best thing to do, I thought timing belt should be changed every 100 K
what should i do, what would happen if i don't...
I have an ideal what would happen, it would be ideal for you to take your valve cover off and take a look at your timing belt to look for wear, or not enough pressure on the belt.
If your timing belt snaps, your valves will be bent, and big problems , but that's my ideal.
168k is way to high. I suppose it would be alright if you drove it like a grandma everywhere. I changed my belt and water pump at 90,000 right when i bought the car. The service manual also says you can go 7500 miles before you change the oil. They are talking best case scenarios i bet. Just change it soon to avoid any further damage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chingles »</TD></TR><TR><TD CLASS="quote">Got a question the service manual for 5th Generation prelude says i should get my timing belt checked at 168,000 K's</TD></TR></TABLE>
By K's do you mean Kilometers or thousands of miles??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">how many miles are in a kilometer? 1.5??</TD></TR></TABLE>
1 mile (US)=1.609344 kilometers
1 kilometer=0.62137119 miles
00siALLmotor
Acura TL, RL & ZDX
Jan 30, 2005 09:31 PM
