Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
upper c/a swap?
Old Dec 18, 2001 | 07:53 AM
Lo-Buck EF's Avatar
Default upper c/a swap?
anyone know if the upper control arm swap to gain caster will work on '89-'91 civics? also, is it legal in a stock scca autocross class? (not like they'd have to know)
Old Dec 18, 2001 | 08:21 AM
celica73's Avatar
New User
Default Re: upper c/a swap? (SOLOef)
Can't comment on it other than legality for stock autocrossing.
Legal: NO
Like you said, no one is likely to figure it out unless you are really good. Of course it is still cheating.
Scott
Old Dec 18, 2001 | 08:44 AM
r2x's Avatar
r2x
You might be surprised what a National level compeditor will "know" about the legality of your car. Would you *really* want to cheat?
Old Dec 18, 2001 | 08:54 AM
Lo-Buck EF's Avatar
Default Re: upper c/a swap? (r2x)
no, i don't want to cheat. i was just taying that no one is likely to scrutinize an hs car at a local event.
Old Dec 18, 2001 | 08:55 AM
r2x's Avatar
r2x
You are correct, usually even obviously illegal cars are allowed to class themselves incorrectly at local events until one of their compeditors says something. Local clubs are pretty friendly, usually.
Old Dec 18, 2001 | 11:16 AM
johng's Avatar
If the upper control arms are similar in design to the 92-95 upper arms, than yes, they will provide additional caster. With the arms off, you may notice a slight length difference in each side of the "wishbone".
One other thing I noticed......now that every suspension part is off my car, I noticed two small "dents" or impressions in the undercoating where the rear part of the control arm bolts to the upper wheelwell. I don't think these "impressions" were there before I switched mine over. I'd be curious if Karl sees the same thing on his Integra. I'd post pictures, but photopoint has been down for over a week.
Oh Karl......
Old Dec 18, 2001 | 11:31 AM
4doorH22's Avatar
Default Re: upper c/a swap? (johng)
So it seems part of the swapped control arm by the connection to the unibody makes contact with the undercoating/fender liner? The sheet metal isn't touched?
Old Dec 20, 2001 | 12:52 PM
Mista Bone's Avatar
D Tranny Guru
The 88-91 have a different design. The upper ball joint is already towards the rear of the control arm.
Old Dec 20, 2001 | 02:06 PM
krshultz's Avatar
If it's anything like the 94-01 Integra, then yes. For someone who knows what to look for, it's actually pretty easy to tell when it's been done.
TurBoTeG
Suspension & Brakes
Nov 28, 2007 01:48 PM
92integra-R
Mar 1, 2006 09:55 PM
Cornwhiskey
Suspension & Brakes
Nov 28, 2005 05:54 AM
BIG RICH
Nov 21, 2004 02:53 PM
20
Apr 12, 2004 03:43 AM
