building a poor mans type R - which piston to use p30 or ITR .25 over
Old Oct 19, 2004 | 11:34 AM
JDMvtecDRAGSTA's Avatar
Default building a poor mans type R - which piston to use p30 or ITR .25 over
wassup everyone,
im building a poor mans itr setup
the head is gonna be a b16 (pr3) head - i dont know what the internals are gonna be yet, most likely skunk2 or omni
and the block is a 95 b18c1
the block is getting all the misc work done to it (machining, bearings, seals, rehone...etc)
just wondering which pistons would be better to use - p30's or the ITR .25 over?
thanks
Old Oct 19, 2004 | 11:46 AM
flesh199's Avatar
p30 for sure..
Old Oct 19, 2004 | 11:53 AM
98itr0448's Avatar
Default Re: building a poor mans type R - which piston to use p30 or ITR .25 over (JDMvtecDRAGSTA)
p30's have a little better compression ratio than the jdm itr's, but not as high as the 12:5:1 ctr pistons. P30's would be the better choice if your running a stageI or II cam, although good luck getting your hands on a set
Go to this site. I believe it was created by a h-t member. It has all the stock pistons, blocks, ect to figure out compression. You will want to know this info when choosing valvetrains!
http://technet.ff-squad.com/cr-calculator.htm
at stock bore and stock 3layer head gasket you will have 11:3:1 compression. Mill the head a little or run a two layer gasket and you'll be closer to 11:5:1. This would be perfect for some stageII cams. I'd recommend hondata or some kind of tuning platform with that compression though.
Old Oct 19, 2004 | 03:02 PM
AzG35's Avatar
Default Re: building a poor mans type R - which piston to use p30 or ITR .25 over (98Itr-0448)
Either is fine, the CR won't be that much different .1-.2
Old Oct 19, 2004 | 09:21 PM
alphanumeric's Avatar
Default Re: building a poor mans type R - which piston to use p30 or ITR .25 over (AzSi22)
get the itrs .25 over so i can have the p30s baahah
RITLINBOY-91.SI
12
Jun 9, 2012 09:46 PM
divinition
Apr 28, 2009 12:52 PM
JDM_EK4_Coupe
Jun 27, 2007 11:45 AM
92integraVTECgsr
Mar 27, 2006 08:09 AM
jdm jedi
Apr 23, 2004 07:58 PM
