how to stop wheel hop?
Old Oct 19, 2004 | 11:24 AM
B16Civic93's Avatar
Default how to stop wheel hop?
i have a 93 coupe ex with a second gen b16 with a few bolt ons, i am running faulken azenis and a couple weeks ago i blew a hole in the bottom of my tranny from what i'm guessing was wheel hop because it had alot. is there anything that i can do to make wheel hop happen less, keep in mind this is my daily driven car. thanks in advance
Old Oct 19, 2004 | 11:41 AM
Machine1's Avatar
Default Re: how to stop wheel hop? (B16Civic93)
Traction bars and slicks help.
Old Oct 19, 2004 | 03:25 PM
Street Ghost's Avatar
Traction bars and maybe even stiffer mount mounts.
Old Oct 19, 2004 | 10:48 PM
L-CON1's Avatar
Default Re: how to stop wheel hop? (_Project EJOne)
i can help your traction problem, pm me!
Old Oct 19, 2004 | 11:15 PM
ATS*Mark's Avatar
OG triple OG
Default Re: how to stop wheel hop? (fab1)
l-con's!!!!!!!
Old Oct 20, 2004 | 09:17 AM
Adam.'s Avatar
Default Re: how to stop wheel hop? (Hella_JDM)
I had a bad problem with wheel hp with normal HCP mounts and soft shock settings. I actually pulled them and filled in teh space between the inserts with an extra insert, making them completely solid. I also stiffened my shocks to full stiff. The next time I went i had no wheel hop at all. It just turned into wheel spin. I went from pulling inconsistent low 2.2s - low 2.3s to very consistent high 2.1s and low 2.2s.
Old Oct 20, 2004 | 10:36 AM
ModenaTwinTurbo's Avatar
Default Re: how to stop wheel hop? (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]I had a bad problem with wheel hp with normal HCP mounts and soft shock settings. I actually pulled them and filled in teh space between the inserts with an extra insert, making them completely solid. I also stiffened my shocks to full stiff. The next time I went i had no wheel hop at all. It just turned into wheel spin. I went from pulling inconsistent low 2.2s - low 2.3s to very consistent high 2.1s and low 2.2s. </TD></TR></TABLE>
thats good info rite there.
Ed-
Old Oct 20, 2004 | 11:01 AM
bubbahatch92's Avatar
You should also try getting rid of those tires. The stiff side wall is known to cause wheel hop. I went through my whole suspension and did'nt get rid of my wheel hop til i got rid of the azenis.
Old Oct 20, 2004 | 11:41 AM
Adam.'s Avatar
Default Re: how to stop wheel hop? (bubbahatch92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubbahatch92 &raquo;</TD></TR><TR><TD CLASS="quote">You should also try getting rid of those tires. The stiff side wall is known to cause wheel hop. I went through my whole suspension and did'nt get rid of my wheel hop til i got rid of the azenis.</TD></TR></TABLE>
I am running azenis on my setup.
Old Oct 22, 2004 | 07:12 PM
L-CON1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">l-con's!!!!!!!</TD></TR></TABLE>?
prelude2.2vtec
Sep 20, 2007 03:43 AM
civicsaremean
18
Jul 23, 2007 11:17 AM
Marlon88
Apr 23, 2005 08:11 AM
msmithgsr2131
Feb 16, 2004 08:59 AM
yellowbuffalo
Jul 2, 2002 11:41 PM
