what are all the factors that cause the annoying revving when the motor is cold?
i think its normal when the motor is cold
i guess its trying to bring the motor up to operating temp faster with a higher idle
i mean it revs up and down consistantly. in my moms crx it revs endlessly, even if its been running for 30 minutes and even when its already warm.
a few things can cause it. on single cams there is a valve assembly at the bottom of the throttle body, in it there is a valve. unscrew the 2 screws on the flat plate and you will see a round piece of plastic with slots on each side, you can screw it in all the way if it is loose and it may solve the problem, also if not this, iacv on the back of the intake manifold, bad tps, or possible vacuum leak.
fast idle throttle valve...located under the throttle body
replace that then go from there
lsxtreme81
Apr 20, 2007 05:39 PM
g2style
Feb 6, 2003 12:46 PM
