Couple of Questions
Old Oct 19, 2004 | 08:18 AM
counterfeit3w's Avatar
Default Couple of Questions
I just recently purchased a 91 DX Civic Hatch from a friend of mine. The motor is blown and I am going to replace it with a different engine. I know that a B16 or ZC motor would be the easiest. I would like to do the B16 swap, but there seems to be alot more work involved then I thought. What exactly has to be modified on the civic for this motor to work? The company I am getting this motor from includes ecu, axles, tranny and all the other conponents that I will need. Is there a complete swap guide out there? Any info would help.
thanks,
james
Old Oct 19, 2004 | 08:23 AM
DeKaP's Avatar
Default Re: Couple of Questions (counterfeit3w)
whoever told you a b16 is easy to install is mistaken
theres always some type of problem you'll run into, i still havent finished mines, but than again im a dumbass
Old Oct 19, 2004 | 08:26 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Welcome to Honda-Tech..
If you check at the top of this forum,you will see a FAQ
or "Frequent Asked Questions" section..
There are several links contained within that should help..
Or just click here:
https://honda-tech.com/zerothread?id=637661
To run either engine in a DX you will have to convert it to MPFI.
[Multi-Port Fuel injection]
Look for the links on "DPFI to MPFI" for explanation of this process..
DenzComp
May 12, 2007 09:07 AM
JJ's civic
Apr 30, 2006 03:35 PM
1991hondahead
May 10, 2004 11:11 PM
vg30dett71510
Apr 28, 2003 01:19 PM
B16CivicHB
Jan 4, 2002 01:05 AM
