i need window help asap
i drove to work last night and it was rainin pretty bad. i smoke so i had my window cracked. i guess i didnt close the window all the way because when i got back there was a bunch of water in my car. i started it and the drivers side window went down without me touching the switch. i tried to get it to come up but its stuck down. now when i press the switch it makes a noise but does nothing. its not off of the track or anything.
98 ex coupe
a lil help before i have to drive to work in the rain again
EDIT
is there a way i can manually get the window closed? or a way that i can jump the switch? thnx for all help
98 ex coupe
EDIT
If its just the switch thats ruined(which it probably is), you can take the door panel off and jump the motor directly to the battery, so you can get the window back up.
Just touch power to one pin and ground to the other, if it tries to go down more, reverse the power and ground, then it should go up.
Thrillhouse
Nov 9, 2003 07:19 PM
