O2 (oxygen) sensor simulator HELP!!!
Old Oct 19, 2004 | 07:26 AM
nkt001's Avatar
Default O2 (oxygen) sensor simulator HELP!!!
Has anyone ever used an oxygen sensor simulator to simulate the secondary O2 sensor before......I'm trying to use one on my 1996 Civic EX coupe and cannot seem to get it to work. If you have used one, please let me know how you connected it.
Any information would be apprecaited!!
Old Oct 19, 2004 | 08:31 AM
JDMallTHEway's Avatar
Default Re: O2 (oxygen) sensor simulator HELP!!! (nkt001)
my friend did, he just wired the sim chip into the ecu, replacing 2 of the o2 sensor wires.
Modified by JDMallTHEway at 2:35 PM 10/19/2004
Old Oct 19, 2004 | 12:19 PM
nkt001's Avatar
Default Re: O2 (JDMallTHEway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway &raquo;</TD></TR><TR><TD CLASS="quote">my friend di, he just wired the sim chip into the ecu, replacing 2 of the o2 sensor wires.</TD></TR></TABLE>
Did he take power from the heater circuit to power the simulator??
Old Oct 19, 2004 | 01:43 PM
bradmanuwf's Avatar
I cut the signal wire and attached the sim signal wire. I grounded it to the ECU ground and powered it from an ECU power wire that I was using for my SAFC also. I just twisted the wires together and then spliced them in. just leave the heater wires alone. you don't need to mess with those. All is needs is 12v from where ever and a ground. then just cut the O2 signal wire and replace it with the sim chip wire and you're good to go. I'm the friend that jmdalltheway was talking about.
Modified by bradmanuwf at 3:31 PM 10/19/2004
Modified by bradmanuwf at 3:32 PM 10/19/2004
Old Oct 19, 2004 | 03:12 PM
nkt001's Avatar
Default Re: O2 (bradmanuwf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradmanuwf &raquo;</TD></TR><TR><TD CLASS="quote">I cut the signal wire and attached the sim signal wire. I grounded it to the ECU ground and powered it from an ECU power wire that I was using for my SAFC also. I just twisted the wires together and then spliced them in. just leave the heater wires alone. you don't need to mess with those. All is needs is 12v from where ever and a ground. then just cut the O2 signal wire and replace it with the sim chip wire and you're good to go. I'm the friend that jmdalltheway was talking about.
Modified by bradmanuwf at 3:32 PM 10/19/2004</TD></TR></TABLE>
What kind of car?? Also, have you passed emissions test with this setup??
Old Oct 19, 2004 | 04:05 PM
bradmanuwf's Avatar
Default Re: O2 (nkt001)
03 civic ex, and I didn't have to pass emissions. I'm in FL/AL. If you're in a state that has emissions tests, you won't pass if the cat is not factory or gutted. In other words, YOU ARE SCREWED IF YOU HAVE A HIGH FLOW CAT (like me) OR HAVE GUTTED THE CAT. sorry dude. I hope you saved the factory cat if you have a high flow, cause then you can just switch them out for the test and then switch it back.
Old Oct 19, 2004 | 07:12 PM
nkt001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradmanuwf &raquo;</TD></TR><TR><TD CLASS="quote">03 civic ex, and I didn't have to pass emissions. I'm in FL/AL. If you're in a state that has emissions tests, you won't pass if the cat is not factory or gutted. In other words, YOU ARE SCREWED IF YOU HAVE A HIGH FLOW CAT (like me) OR HAVE GUTTED THE CAT. sorry dude. I hope you saved the factory cat if you have a high flow, cause then you can just switch them out for the test and then switch it back.</TD></TR></TABLE>
Actually, if I could just get the CEL off, I would be OK, becuase here they just hook up to the ECU and check for codes.......if something is wrong however, they will hook up the sniffer and check the actual output of your car......that is why I need the simulator.....to get rid of the CEL
Old Oct 19, 2004 | 08:36 PM
then that should work.
Old Oct 20, 2004 | 09:12 PM
jlv55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway &raquo;</TD></TR><TR><TD CLASS="quote">then that should work.</TD></TR></TABLE>
question is....HOW?
Old Oct 20, 2004 | 10:03 PM
ki11a8ee's Avatar
Default Re: O2 (klutch44)
i dont know where ur from but if u fail the obd2 test u fail automatically im from illinois.
Old Oct 21, 2004 | 03:01 PM
bradmanuwf's Avatar
Default Re: O2 (ki11a8ee)
we're in FL where we don't have inspections. and if you put in the sim chip correctly, the tester won't even know its there cause the ecu will think its the sensor. the only thing u'd be screwed on is if they put the sniffer to the tail pipe. then you are f'ed.
Old Oct 21, 2004 | 03:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradmanuwf &raquo;</TD></TR><TR><TD CLASS="quote">we're in FL where we don't have inspections. and if you put in the sim chip correctly, the tester won't even know its there cause the ecu will think its the sensor. the only thing u'd be screwed on is if they put the sniffer to the tail pipe. then you are f'ed.</TD></TR></TABLE>
agreed.
jDMJeRk
Oct 3, 2019 08:19 PM
JDMsi31
Nov 25, 2007 08:48 AM
bboysakeq4
Jan 18, 2007 06:45 PM
