Integra/drag/show/street class winner 4sale
Original owner-purchased 5/94 1994 Acura Integra Race/Show car. 2001 Type R interior. Fiber Images Carbon Fiber Gen II hood. at least a $5500 paint job minimal inside and out. most stock parts will come with the car. Koni single adjustable shocks with Skunk2 coilovers. 2 different sets of springs for rear to go with the car. Type R front strut bar. Rota C8 16x7 rims(painted black)with toyo track street tires. neuspeed short shifter. jdm integra radio block off plate. Sparco Racer2 steering wheel. oil catch can. b18c5 block resleeved(thicker)and bored to piston specs. stock crank(untouched). Eagle rods (gsr stock length). Endyn 84.5mm 13.1:1 compression pistons. Honda crv head gasket. head and block sealed off for vtec oil passage(crv gasket doesn't have this. GSR head worked extensively and i do mean extensively included filled and port matching to twm ITB's. head milled roughly 3-5thou to clean(literally) the surface. .5mm oversized ferrea valves. Toda valve springs. Portflow titanium retainers. Toda Spec C cams. Toda second gen cam gears. TWM 50mm Individual Throttle bodies. TWM fuel regulator. TWM 440cfm injectors. Toda Oil pump gear. Unorthodox underdrive pulley. Toda flywheel. Clutchmasters stage5 clutch package with extreme Pressure plate. DFI fuel management. MSD 6al. MSD rpm activation switch for vtec activation. MSD distributor cap. Jacob's Electronics Ultra coil. MSD 8.5mm wires. NGK R1 crazy plugs(20bucks a piece). Stock ITR fuel pump. Oil passage routed from block to head(remember the block off). 9200rpm ignition and fuel cutoff. complete color change. other photos upon request This car has won many many events the past 3 years. the first 2 years was with a different drivetrain then this full buildup. The 5 events this year alone it won 3 and made it to the semi finals in the pro ALLMOTOR import class the other 2. Once again..more info upon request if needed. Car has major sponsorship and can be seen here... times its run and places it can be seen 12.54 with 108.99mph trap speeds allmotor. You can go to these websites for more photos... http://www.todaracing.com/cars.html http://www.hytechexhaust.com/honda/content_drag.htm http://www.ahmotor.com/performancedivision/index.html -car when it was white http://www.drtracing.com/drt.htm - my engine builder
its all over http://www.urbanracer.com http://www.premiercompacts.com/ etc etc...
some photos
all stock parts will be included with car. 19,000 absolutely firm.
some photos
No...its called Aztec Yellow. Its a stock chrysler color that hasn't made it to the pt cruiser yet.
i really want to sell it to begin the next project
thanks
thanks
i IM'd ya. still have it but need to either use it for events this year if its not sold...or move onto to my mini. its one or the other...not both sadly.
and still forsale. car is now caged and some other goodies added and go with it including spare gutted and lexaned doors and hatch. I pretty much let the sale go away til race season.
can the car be drivien daily without problems, and if one was to get a regular intake manifold like a oem type r whould this take away alot of power, if i were to buy i whould rather have a regular style intake manifold, if it whould take away alot of power is it safe to drive everyday likee that or could you put some kind os screen or somthin by the openings, sorry for all the questions
thanks
eric
thanks
eric
