My BaseLine Dyno with M22s
Old Oct 19, 2004 | 05:20 AM
VtecKiDD's Avatar
Default My BaseLine Dyno with M22s
Posted this in the All Motor FOrum
Here it is, my baseline dyno graph. Notice how rich it is around Vtec engagement (5800rpms) off the charts like 8:1. So pretty much what i learned fomr this is that im not lean an im not detonating
This is the best i dynoed, It actually broke up in vtec for a second as you can see cause like a dumass i added fuel instead of leaning it out. this was the second run. The Tq curve was kinda all over the place too which i thought was weird.
This is all 3 of my runs. overlapped
I made peak power around 8400-8500 rpms. i made peak tq arounf 8k rpms. I had vtec set at 5200 for the 1st run then 5800 for the last. As you can see it needs a good tuning session. Im trying to get to Mainstream this week to play with it. Keep in mind I made NO FPR, Cam gear adjusments an MINOR vafc adjusments. I think with soe real tuning an a few more degrees of timing i can hit 190-195 whp which was my goal. When my ported head gets here i want 210-215
Mods are
GSR block 81.5mm
decked .10 11.5:1 compression
B16 head
M22 cams an valvetrain
AEBS mildly ported intake manifold
ANR header
S2 cam gears
Walbro 255 fuel pump (came in the car)
H22 290cc injectors
B+M adj FPR
Nopi #1 intake
Old Oct 19, 2004 | 05:47 AM
mrspeaker's Avatar
Default Re: My BaseLine Dyno with M22s (VtecKiDD)
For a baseline dyno thats pretty good with that set-up..
get it tuned and its gonna be a monster..
over 200whp is gonna be pretty hard..but if u get a good tuner it could be done.
U probablly woudn't even hit 150hp without the NOPI Intake..
Old Oct 19, 2004 | 05:59 AM
VtecKiDD's Avatar
Default Re: My BaseLine Dyno with M22s (Mrspeaker)
lol, yeah. i think 190-195 is possible. I really need to get my head done, as you can see it kinda hits a wall at 8krpms. 1st gen B16 head cant flow much past 8300-8400 from what i have seen.
I needed an intake an i was kinda broke. I was running on a sock that was ziptied around my TB The Nopi brand intake is 2.5inch piping an i got it for $28 including filter lol.
ProjectBB6
Jan 19, 2010 02:13 PM
EM1B18-R
Aug 3, 2005 10:03 PM
VtecKiDD
Oct 18, 2004 05:01 PM
int3gra
May 22, 2002 01:40 PM
