Where do i look to get the Main bearing code, and the rod bearing code?
Old Oct 19, 2004 | 05:08 AM
s2kkid's Avatar
Default Where do i look to get the Main bearing code, and the rod bearing code?
im buying bearings for the eagle rods im getting, and new main bearings.
Id like to stick with honda bearings, Will these work with the eagle rods?
Most importantly- Ive heard that you look on the block for the main bearing code, and you look on the rod for the rod bearing code,
How do i identify these?
Old Oct 19, 2004 | 07:38 AM
B SERIES US's Avatar
Default Re: Where do i look to get the Main bearing code, and the rod bearing code? (vtecluder97)
the codes are on the block on the top right by the rear main seal..its 4 0r 5 numbers...then there are numbers on the crank between each weight read the num on the block from left or right and do the same with the crank i will have 2 num..ex..if the num on the block is 4 then the num on the crank is 3 then u look in the honda serv man.and see what color ber u need 4 the num 4 on the block and 3 on the rod u do the same with all the num...uas the num on the crank ane the num on the rods if they where stock the same way u didi the block is the same way u do the rods do get the right color ber..but u realy need to call your local acura parts dpartment to get the right bearing if u have any problems hait me up at sedate88civic@yahoo.com
Steady R
Aug 7, 2012 10:19 AM
desmone
Mar 18, 2007 04:39 PM
panchovilla760
Mar 2, 2007 09:26 PM
1 Cam Wonder
Jan 24, 2005 08:29 AM
joker1626
Jul 1, 2004 08:20 AM
