Quick Caster Question (searched)
Old Oct 19, 2004 | 02:14 AM
jdmkrazie's Avatar
Default Quick Caster Question (searched)
ok i tried to search.. but then ended up getting tired of looking through so many topics.
so heres the question.. if i adjusted my caster.. would it change my toe or any other adjustments on my alignment?
btw... i know caster isn't adjustable on my integra.. i just need to know the answer to the question so i can figure out if i need to get another alignment.
Old Oct 19, 2004 | 06:06 AM
JimBlake's Avatar
Default Re: Quick Caster Question (jdmkrazie)
Most of the time, when you adjust one thing, the others all change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote">btw... i know caster isn't adjustable on my integra.. i just need to know the answer to the question so i can figure out if i need to get another alignment.</TD></TR></TABLE>So how did you adjust it?
Old Oct 19, 2004 | 07:02 AM
mmuller's Avatar
Mad Scientist
did you swap uca's?
Old Oct 19, 2004 | 12:47 PM
jdmkrazie's Avatar
Default Re: Quick Caster Question (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Most of the time, when you adjust one thing, the others all change.
i haven't tried adjusting it yet. but what i'm planning on doing is moving the front and rear x-member's and adding some shims. the x-members probably won't move too much but i know it'll change at least a little since the reason why i'm trying to adjust my caster is because of a previous accident.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">did you swap uca's?
no and i'm not planning on doing that
come on guys... i just need someone who really know's for sure if i changed my caster in anyway if my toe or anything else involving my alignment would change.
Old Oct 19, 2004 | 01:35 PM
JimBlake's Avatar
Default Re: Quick Caster Question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkrazie &raquo;</TD></TR><TR><TD CLASS="quote">come on guys... i just need someone who really know's for sure if i changed my caster in anyway if my toe or anything else involving my alignment would change.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Most of the time, when you adjust one thing, the others all change.</TD></TR></TABLE>It really depends on the exact details of HOW you manage to change the caster. To be safe, I'll say YES IT CHANGES. Because it's not easy to change one without changing the others.
In order to change caster without changing camber, you have to move the upper & lower control arms in a strictly parallel manner. Upper & lower ball joints have to keep the same distance between them (right-to-left), and the control arms have to sit at the same angle as they were.
Now, in order to do that without changing the toe, you'll probably have to relocate the steering rack to correspond with the new position of the steering knuckle. The outer tie rods have to sit at exactly the same angle as they did before.
Old Oct 19, 2004 | 03:12 PM
jdmkrazie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It really depends on the exact details of HOW you manage to change the caster. To be safe, I'll say YES IT CHANGES. Because it's not easy to change one without changing the others.
ok thats all i needed to know. thanks
xDicktonesx
Oct 3, 2006 04:13 PM
Neuspeedx
Jul 1, 2006 09:43 AM
Weston
12
Jan 3, 2005 04:51 PM
dcsportsciv
Oct 27, 2004 07:58 PM
essex
Welding / Fabrication
Oct 3, 2004 10:31 PM
