I NEED HELP!
Old Dec 18, 2001 | 03:46 AM
PorscheGT2's Avatar
New User
Default I NEED HELP!
OK heres the problem, my power steering belt is splitting. this is the second time within the last month that i have split it. This time it did some weird things when it came off. i thought it was just my power steering that i lost, but then like a whole bunch of **** started to happen. my battery light came on and my lights dimmed a lot and couldn't power my windows. when i accelerated my car acted like it was going to stall, it jerked and popped. what the hell is going on with my car?
Old Dec 18, 2001 | 03:52 AM
urbanlegend21's Avatar
New User
Default Re: I NEED HELP! (PorscheGT2)
How tight do you put the belt on?
Old Dec 18, 2001 | 06:05 AM
PorscheGT2's Avatar
New User
Default Re: I NEED HELP! (urbanlegend21)
i didn't put it on, i took it to the shop and they put it on, so i'm guessing they didn't put it on to tight
Old Dec 18, 2001 | 06:07 AM
New User
your cars electrical system went haywire becuase that is the belt that runs the altenator too. That is a common side effect of the belt coming off.
Old Dec 18, 2001 | 07:06 AM
2point6's Avatar
Not to step on anyone toes, The power steering belt is a seperate belt than the alt/ac belt. If the p/s belt split and took out the alt/ac belt that is the reason for the electrical problems. If the belt is too loose it will have a tendancy to "move over" on the p/s pulley meaning half on the pulley half off. This will also lead to splitting. Best bet is to consult a factory manual for proper tensioning.
Check out http://www.collectiveracing.net
Old Dec 18, 2001 | 07:12 AM
New User
Default Re: I NEED HELP! (2point6)
Excuse me, a lot of things on my mind right now, I was completely wrong with my previous post. I totally agree with 2point6 on this. I will also add that if the power steering pump is not adjusted back properly(i.e. ****-eyed or tilted) it will wear your belt unusually.
Sorry for the misinformation.
Old Dec 18, 2001 | 01:07 PM
PorscheGT2's Avatar
New User
Thanks guys, its day time now so i can look under my hood and see everything, my p/s belt totally demolished the altinator belt. but would that make my car almost stall and make loud noises and make my car jerk?
Old Dec 18, 2001 | 01:17 PM
4doorH22's Avatar
Sure. Your battery must be pretty old?
When your accessory belt went, all electronics instantly run soley on the battery, and it didn't have enough amps for your headlights, windows, and especially ignition. When an accessory belt goes, shut off all unnecessary electricals. A properly functioning and charged battery should be able to power a car's ignition for over an hour (that's with no headlights, wipers, stereo, anything).
khronicboy420
Mar 3, 2012 02:39 PM
AondaHcura
Jan 22, 2010 09:28 AM
2002civicrider
Honda Civic (2001 - 2005)
Jun 11, 2008 09:25 AM
HondaH22a#1
Jun 29, 2007 08:27 AM
