best RPM to launch at
Old Oct 18, 2004 | 09:53 PM
Kyles ej1's Avatar
Default best RPM to launch at
i wanna take my car to the track on wed, i got a z6 w/ a cai and act 6 puck w/ street tires, ill prob lower the psi a lot and want to knoe what would be safe to launch at
Old Oct 18, 2004 | 10:35 PM
Kyles ej1's Avatar
Default Re: best RPM to launch at (egcoupe)
up
Old Oct 19, 2004 | 01:50 AM
MAD SOHC's Avatar
You don't need to lower the air pressure for street tires unless they are drag radials. You should be able to luanch around 4500 but thats a trial and error process.
Old Oct 19, 2004 | 04:34 AM
tk's Avatar
tk
You should launch 300 rpm above your max torque
Shift at 400 past your max HP
Old Oct 19, 2004 | 05:21 AM
CNSK's Avatar
trial and error.....start at 2500 or so and work your way up..
Old Oct 19, 2004 | 06:43 AM
UnKnownUser's Avatar
Default Re: best RPM to launch at (Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moua &raquo;</TD></TR><TR><TD CLASS="quote">trial and error.....start at 2500 or so and work your way up..</TD></TR></TABLE>
Yah i would say start about their and work your way up, till its right...
Old Oct 19, 2004 | 06:55 AM
Quik Chris's Avatar
Default Re: best RPM to launch at (tk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tk &raquo;</TD></TR><TR><TD CLASS="quote">You should launch 300 rpm above your max torque
Shift at 400 past your max HP </TD></TR></TABLE>
I dont' really agree with the shift 400rpm past your max HP-- it might work in a domestic car, but as far as Honda's are concerned-- The HP curve is peaky, so when you do shift before redline, the RPM after you shift is going to have less WHP and less torque than it would have staying on the throttle until redline, though this isn't always true, but it's typically the case.
Ding
Honda Civic (2006 - 2015)
56
Oct 3, 2006 08:24 PM
JDM.K20
36
Sep 20, 2006 12:05 PM
AllMotor12s
Apr 9, 2005 01:26 AM
hotdoggies
11
Mar 18, 2005 10:40 AM
DC531
10
Aug 21, 2004 06:16 AM
