DA owners 4-1 header READ!!
What kinda of 4-1 headers w/2.5inch collector are you guys using for your DA with a stock LS motor, how much does it hang low, and did you have to notch your crossmember? If you can, can you take a picture of the bottom of your car so I can see how low it hangs. Thanks
You might look at G2IC.com, I always find all more G2 responses over there.
I can't tell you from experience, but I've read about 99.9% of G2'ers with the DC Sports 4-1 have to notch the crossmember... and that's not even a 2.5" collector. If you have the Full-Race or the Z10 crossmember then you won't have a problem with anything. I can't speak for other headers...
i have a stock jdm itr 4-1 header on my da
and yes you will have to notch the crossmember with any 4-1 header 2.5 inch or not
also the jdm itr 4-1 header will not clear the ls/b16 oil pan and a jdm itr 4-1 header is only compatiable with a p72 gsr/itr oil pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">i have a stock jdm itr 4-1 header on my da
also the jdm itr 4-1 header will not clear the ls/b16 oil pan and a jdm itr 4-1 header is only compatiable with a p72 gsr/itr oil pan </TD></TR></TABLE> Some guy on g2ic said that he has a 4-1jdm itr header and the only modification he did was notch the crossmember. Here's the link http://g2ic.com/forums/showthr...35167
First of all, a 2.5" 4-1 header is overkill for a stock ls. With that out of the way:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">Yea I was checking g2ic.com out but no one provided pictures and their search sucks. I like honda-tech better, better responses and theres more pictures. BUMP!</TD></TR></TABLE>
G2IC's search usually provides MUCH better results than HT's, just because HT has Soooooooooooooo many threads on soooooooooooo many repetitive topics.
But to answer ur original question: On 90-91s, you're gonna have to notch your crossmember, on 92-93's it'll fit just fine, well it'll be cozy, but it'll fit. Most of the people that install a 4-1 notch it anyway just so there's a bit more play and they don't have to worry about crossmember/header collision.
and regarding this statement:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">also the jdm itr 4-1 header will not clear the ls/b16 oil pan and a jdm itr 4-1 header is only compatiable with a p72 gsr/itr oil pan </TD></TR></TABLE>
I'm pretty sure you're wrong here...someone else wanna jump in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote"> Some guy on g2ic said that he has a 4-1jdm itr header and the only modification he did was notch the crossmember. Here's the link http://g2ic.com/forums/showthr...35167</TD></TR></TABLE>
That's me. The oil pan had to be slightly persuaded with a hammer as well (very slightly).
Ground clearance is actually very good, considering. I'll do my best to get some pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS »</TD></TR><TR><TD CLASS="quote">First of all, a 2.5" 4-1 header is overkill for a stock ls. With that out of the way:
I'm pretty sure you're wrong here...someone else wanna jump in?</TD></TR></TABLE>
Any 90-93 xmember will have to be notched. From my understanding there is no difference.
My JDM ITR 4-1 wouldn't clear my LS oil pan. It was close, but it wouldn't clear.
yes it will one of ma best freind has a DA lsvtec with jdm 4-1 headers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">Any 90-93 xmember will have to be notched. From my understanding there is no difference.</TD></TR></TABLE>
The 92-93 tegs come stock with a 4-1 header, some aftermarket 4-1s will fit without having to be notched
The 92-93 tegs come stock with a 4-1 header, some aftermarket 4-1s will fit without having to be notched</TD></TR></TABLE>
Perhaps you're thinking of the GSR...? I'm pretty sure even the 92-93 GSR didn't have a 4-1 from the factory.
Daym dude, i have a feeling if i get a jdm 4-1 header, 95% percent of the time it'll be on the floor. Here are some pictures, tell me if u think i'll make it
and tell me if u dont think i can
. My 4-2-1 dc header is basicly 2inches off the floor.
Pic 1 (ciggarrete box under it)
Pic 2 (mothers polish beside it)
Pic 3 (size of mothers polish)
Modified by UNKNOWN_MEMBER at 1:57 AM 10/20/2004
Modified by UNKNOWN_MEMBER at 2:03 AM 10/20/2004
. My 4-2-1 dc header is basicly 2inches off the floor.Pic 1 (ciggarrete box under it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">I know this isnt the same application but it helps.
88 Crx 1.8L vtec. 4-1, 2.5" collector.
yourwelcome.</TD></TR></TABLE> Do you drive your car daily? How well do you get over speed bumps and just crazy road bumps?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote"> Do you drive your car daily? How well do you get over speed bumps and just crazy road bumps? </TD></TR></TABLE>
Dont you go sides ways over the speed bump?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC DC4 »</TD></TR><TR><TD CLASS="quote">
Dont you go sides ways over the speed bump?</TD></TR></TABLE> Yea i go sideways. But i mean daily driving on freeways and ****, its hard to avoid all bumps.
Its alright for DD, speedbumps it usually clears, the header (i have a lower spot farther down where the cat bolts up) Its bottomed before, but i have no dents yet. Im more worried about the oil pan which is still good. I might invest in making a skid plate that sits on the header and is bolted to the crossmember.
Over huge bumps the pushing the header back pulls foward on the exhaust manifold studs, cant be too healty. Atleast with some sort of skidplate it will drift over it easier.
-Eric
-Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">If your worrid about clearance, and got some cash go bisi.</TD></TR></TABLE> Bisimotos headers are 4-1 w/ 2.5 collector? Will it fit with a stock radiator?
