HF vs Si gearing question
Old Dec 18, 2001 | 02:58 AM
Chuckles's Avatar
New User
Default HF vs Si gearing question
The '91 HF uses a 2.9 FD while the SI uses a 4.2 FD. Are 1st-5th gears the same with the only difference being the FD? In Honda-Challenge the gear ratios must stay the same, but the FD can be changed. I'm trying to figure out if I can just swap in a SI tranny or will I need to pull it apart. Thanks.
Old Dec 18, 2001 | 04:02 AM
blunty's Avatar
Default Re: HF vs Si gearing question (Chuckles)
According to my book:
--------HF-----------------Si
1-----3.250-------------3.250
2-----1.650-------------1.894
3-----1.033-------------1.259
4-----0.823-------------0.937
5-----0.694-------------0.771
R-----3.153-------------3.153
FD:
HF 2.954, 3.250(Cal)
DX 3.888
Si 4.250
Hope that helps.
[Modified by blunty, 8:04 AM 12/18/2001]
Old Dec 18, 2001 | 04:22 AM
Chuckles's Avatar
New User
Default Re: HF vs Si gearing question (blunty)
Thank you!
Old Dec 18, 2001 | 05:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Or you could just buy my B16A swap with the nicey J1 tranny!
You know you want it Chuckles...
Old Dec 18, 2001 | 05:26 AM
brusk's Avatar
The gearing is different. I don't remember all the specs but first gear is the same.
Old Dec 18, 2001 | 05:31 AM
brusk's Avatar
Default Re: HF vs Si gearing question (brusk)
What engine do you have. If you have the HF I wouldn't worry about the gearing to much as the powerband on the HF is wide and the gearing doesn't seem to make any difference. Somebody changed the first 2 gears in my HF when I bought it and it wasn't any faster. I little more fun at times but not faster. 1st gear would go 30MPH and second would do like 55. Which for an HF isn't right. Had to redline it everytime in first gear so it would be at like 1500 RPM's when on the second shift.
Old Dec 18, 2001 | 06:38 AM
Chuckles's Avatar
New User
Yes, it is an HF. What gears were installed in your HF? Changing from a 2.9 to a 4.2 is a pretty significant reduction if OE HF gears are retained.
Second question: Would a '87 SI FD fit a '91 tranny? Don't know if there are any differences. Thanks.
Old Dec 18, 2001 | 06:39 AM
Mugen Dom's Avatar
L3 tranny should work huh
madhatter07
Aug 30, 2005 11:35 PM
niceguy12
32
Mar 17, 2005 11:39 PM
AZTEKEF9
15
Dec 10, 2004 06:39 PM
out_of_order
Jul 6, 2004 10:46 AM
Nossy
Apr 24, 2002 02:49 AM
