Brake fade?
My Integra has some break fade, Well acually it is bad. I dont believe there is air in the break lines. See when I step on the break, it gets hard then, gets soft and goes closer then closer to the floor? what is going on here? bad Master cylinder?
I don't believe that's called brake fade. Brake fade is where you get the gasses trapped between the pad and the rotor so no amount of hard braking gets the car to stop in a reasonable amount of time.
The pedal feel is the same under brake fade, it's just that the car doesn't really stop as fast.
NuclearB18B
Jul 5, 2005 07:21 AM
