swaping a 5th gen prelude cluster in a 5th gen accord...
Old Oct 18, 2004 | 07:04 PM
fcuk_it's Avatar
Default swaping a 5th gen prelude cluster in a 5th gen accord...
has anyone ever done this or think its possible... it looks like a direct swap but im not too sure...
Old Oct 18, 2004 | 07:19 PM
WesQ's Avatar
Default Re: swaping a 5th gen prelude cluster in a 5th gen accord... (fcuk_it)
I've seen this done before but I think there's some fabrication you need to do. I don't think it fits right in although I could be wrong. Try running a search. You should drop in an H22 to go along with it
Old Oct 18, 2004 | 07:57 PM
fcuk_it's Avatar
Default Re: swaping a 5th gen prelude cluster in a 5th gen accord... (WesK24)
yeah thats the idea if the cluster swap works...
Old Oct 18, 2004 | 11:58 PM
Nick H's Avatar
New User
you have to custom wire everything...the harnesses do not convert from one to the other...i'm assuming you want to do this b/c you have an h22 in your accord...just try to find an si-r cluster on ebay like i did...they are only like $200ish...they go up on there every once in a while...and the extra $100 you pay for the cluster as opposed to the 5th gen prelude cluster will save you headaches and wiring problems that you will encounter...
Old Jan 12, 2005 | 05:19 AM
tiaccordsh's Avatar
Default Re: swaping a 5th gen prelude cluster in a 5th gen accord... (Nick H)
Yeah it is a real pain in the ***,, I have it done, but i wouldnt recomend it.
Obama
May 30, 2008 04:01 PM
oem_certified_accord
Oct 30, 2007 10:01 AM
edtek
Jul 23, 2006 08:43 AM
teamblend
May 2, 2005 02:01 PM
aktc167
Oct 31, 2003 09:25 AM
