Winter Tire questions ?????????????????? TIRE SIZE QUESTIONS
I live in Northern BC Canada and my stock tire size for my civic on stock rims is 185.60 R14 WILL 185.70 R14 tires Fit??
or do i have to run the stock size?
I am just looking for a quick answer so i can by the tires today as its only
8"00 pm here?
8"00 pm here?
185/70-14 will fit - however it will lengthen your gearing slightly, cause your speedometer to read 6.4% lower than your actual speed (i.e. when your speedometer indicates 60mph, you will actually be traveling at ~64mph), and cause your odometer to rack up mileage 6.4% slower.
If you do not mind these effects, go ahead and buy that size. If you do mind, use the stock size or something with a comparable overall diameter.
This tire calculator may help you.
