power steering fluid
Old Oct 18, 2004 | 05:15 PM
rmwarriors's Avatar
Default power steering fluid
I recently drained the power steering fluid from my Prelude by pulling off the hose off the tank (holds the ps fluids) and then refilled the PS fluid back up to max. My questions is do I have to bleed the system and if I do ... how do I do it?
Old Oct 18, 2004 | 05:40 PM
mgags7's Avatar
Default Re: power steering fluid (rmwarriors)
it will bleed itself....you dont have to do anything...the bubbles...if any...will rise to the top of the reservoir and then it will be fine..., but you realize that changing the fluid by draining the radiator barely changes anything....i have never changed it the real way but i would imagine theres a drain on the rack somewhere....back to the point...just fill it up and your ok
Old Oct 18, 2004 | 07:30 PM
vinuneuro's Avatar
Default Re: power steering fluid (mgags7)
how often r u supposed to change the fluid? Is it based on miles or time?
Old Oct 18, 2004 | 08:00 PM
fe519's Avatar
Default Re: power steering fluid (vinuneuro)
good question... i havent changed mine is a long long time
Old Oct 18, 2004 | 10:44 PM
SKDRCR's Avatar
Default Re: power steering fluid (fe519)
You don't have to bleed it.
I change mine about every 20k miles or once a year.
I'm not positive on what the Helms says on it though.
Old Oct 18, 2004 | 11:11 PM
ryanstev's Avatar
When it's new it's nice and pink, so look at the colour of it and make a judgement call.
The best way to replace it is to pour in some automatic transmission flush, turn your wheel full lock to full lock 10 times, then use a machine to suck out the fluid from the bottom of the reservoir while adding the new fluid to the top.
This way gets most of the old stuff out.
curtie94
Feb 24, 2012 12:38 PM
dleccord
May 15, 2010 12:36 PM
old_school_dohcvtec
Jan 18, 2006 03:23 AM
Kavehman
Jul 11, 2005 06:51 AM
Understeer
Apr 4, 2004 12:02 AM
