The heat of the Prelude..?#!
Old Oct 18, 2004 | 03:12 PM
951dc5's Avatar
Default The heat of the Prelude..?#!
I have a 93 lude vtec, one day is was driving down the block to talk to a friend. He came stood aside the my prelude, he said "damn you car is hot coming from underneath the car." I step out and i felt it also, it was like HOT..like your standing next to big heater machine feelin hot air from toe to head.
IS this normal for all prelude? Or something's wrong with my car?
Old Oct 18, 2004 | 03:35 PM
hond_4_me's Avatar
Default Re: The heat of the Prelude..?#! (Prelude951)
you shore the air flow isnt clogged. check if u have enough water.
look at the radiator and hoses check for splits and stuff like that.
Old Oct 18, 2004 | 03:40 PM
hondaZvic's Avatar
is ur temp gauge hotter than normal? if not, dont worry.
Old Oct 18, 2004 | 03:44 PM
napalm_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">is ur temp gauge hotter than normal? if not, dont worry.</TD></TR></TABLE>
these hondas get hot so dont worry, they're made like that
Old Oct 18, 2004 | 08:20 PM
951dc5's Avatar
Default Re: The heat of the Prelude..?#! (napalm_srv)
The water are good since i fill em, and my temp gauge are normal. Hopefully this is normal and won't hurt my car. Ohh! and yeah, everytime i fill or top the water on the radiator and add coolant in the reserve bottle, i notice it's empty. Does it mean there's a hose leakin becuz i don't see any wet spot anywhere..
Old Oct 18, 2004 | 09:13 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
mine blows hot air on hot days when it warms up a little and after i park it the cooling fan turns on. it blows hot air out from under the car... that's what it's supposed to do. If it wasn't on a warm day though you may wanna check out little things... make sure you don't have a leak somewhere or make sure your radiator cap looks ok and the sticker hasn't been broken.
Old Oct 18, 2004 | 10:33 PM
Slipknt777's Avatar
Default Re: The heat of the Prelude..?#! (PreIudeSI)
you might also wanna check your thermostat cause one day i was driving normal and felt my feet getting really hot and the bay was really hot but the temp guage didnt show that it was hot. Then it started steaming from under the hood where the radiator was boiling over. I took it to Goodyear and they replaced my thermostat cause it wasn't working.
as a side note...always run more than one radiator fan. the previous owner did not and it almost cost me alot.
Old Oct 19, 2004 | 03:37 PM
951dc5's Avatar
Default Re: The heat of the Prelude..?#! (Slipknt777)
Yeah i had the same experience like getting my foot hot around the lower area of the pedals, even in the moring and night when its not hot i can feel my foot warm even i had the temp in cold. I just recently changed my thermostat and installed a new radiator. this is weird dude..
Old Oct 19, 2004 | 04:53 PM
spnbb2
Guest
Posts: n/a
engines are HOT, your going to feel HEAT!
Rotting Prelude
Sep 21, 2015 03:15 PM
preludeSRV
Apr 23, 2008 08:34 AM
AnthonyG2003
Nov 27, 2005 03:56 PM
93preludeBB
Sep 14, 2004 08:06 PM
B18C_EJ8
Jan 11, 2004 06:00 PM
