Foam vs K+N filter
Old Dec 17, 2001 | 09:15 PM
Kelvin96GSR's Avatar
25 Year Member
Default Foam vs K+N filter
Just installed a comptech icebox I have both a K+N fitler and the Comptech foam filter which one is better performance wise?
Old Dec 17, 2001 | 09:17 PM
Bob#455's Avatar
Default Re: Foam vs K+N filter (Kelvin96GSR)
The foam might flow slightly better, but at the expense of more dirt getting in through the filter... Which K&N do you have?
Old Dec 17, 2001 | 09:20 PM
25 Year Member
Default Re: Foam vs K+N filter (Bob#497)
Not sure it was a drop in filter that I modded to mate wtih the stock intake tube.
Old Dec 17, 2001 | 09:52 PM
Bob#455's Avatar
Hmm, I did the same thing, but now K&N has released a drop-in replacement filter. It's just as big as the stock one, so it might flow a little better compared to the hacked stock elbow/K&N combo.
Old Dec 17, 2001 | 09:56 PM
25 Year Member
oh really? What model number is it? Does anybody else know anything about K&N vs Foam?
Old Dec 17, 2001 | 09:58 PM
Bob#455's Avatar
The new K&N drop in is part number E-2427.
Old Dec 17, 2001 | 11:58 PM
Tommy_Gunns's Avatar
How come nobody on this board has one of these yet? I've been waiting for someone to post a review.
Old Dec 18, 2001 | 03:17 AM
Darkteg's Avatar
New User
maybe this'll help you:
K&N
Apexi
HKS (sucks)
Old Dec 18, 2001 | 03:27 AM
Piston Honda's Avatar
Default Re: Foam vs K+N filter (Darkteg)
I can't read JDM. So does that mean filtration runs best in this order: Apex, K&N, HKS?
Old Dec 18, 2001 | 03:33 AM
Darkteg's Avatar
New User
Default Re: Foam vs K+N filter (Piston Honda)
right on:
K&N: 13ps
Apex: 14ps
HKS: 13ps
Old Dec 18, 2001 | 04:35 AM
Ex-ITR5874's Avatar
Default Re: Foam vs K+N filter (Tommy_Gunns)
I HAVE one of the new K&N Filters. Bought it some weeks ago..
Old Dec 18, 2001 | 05:37 AM
MiraiZ's Avatar
Default Re: Foam vs K+N filter (Maijk190)
I have HKS...It soils really quickly....but the performance is not as bad as the article says...
Old Dec 18, 2001 | 06:42 AM
jetydosa's Avatar
25 Year Member
Default Re: Foam vs K+N filter (MiraiZ)
The problem I have with the new K&N is that its like $70! Why is it so much, does it come with the elbow thingie too?
I just have a 3130 that was like $30.
Old Dec 18, 2001 | 07:10 AM
BryanSprinkel's Avatar
Default Re: Foam vs K+N filter (Jetydosa)
Where can we order the K&N drop in ? thanks
Bryan
Old Dec 18, 2001 | 07:17 AM
ZygSpeed's Avatar
Default Re: Foam vs K+N filter (BryanSprinkel)
Bryan
If you have the right number ( ...new K&N drop in is part number E-2427), you can get it from Summit/Jegs, etc. HTH
Old Dec 18, 2001 | 07:49 AM
Default Re: Foam vs K+N filter (zygspeed)
Thanks ED,
Bryan
Old Dec 18, 2001 | 10:35 AM
25 Year Member
ok that article makes no sense. How come they say HKS sucks cause its the same flow as the K+N and also the Apexi is only making 1 hp more than the HKS ?
Old Dec 18, 2001 | 10:47 AM
It’s not so much the HP, as the amount of dirt it allows into your engine. Look at the piles of dirt that each allowed. HKS, didn’t fare so well.
Bryan
Old Dec 18, 2001 | 11:19 AM
magic hat #9's Avatar
you could probably say the comptech filter will allow just as much dirt pass through as the hks - both are foam.
riddle me this, can a k&n filter be used in the icebox?
Old Dec 18, 2001 | 11:20 AM
Xian's Avatar
Bryan
You also have to think about the amount of suction that was being used on the filters. I wonder how accurate a representation of actual engine suction that is? Were they using the vacuum cleaner or that twin turbo Nissan engine to check the amount of filtration offered by the different filters?
From what I've seen of the Comptech foam filter (pictures only) it looks like it has more filtration material than the HKS which is a bit on the thin side IMHO...
Old Dec 18, 2001 | 12:02 PM
25 Year Member
Default Re: Foam vs K+N filter (monkey_truckR)
yes it can I am doing it currently
Old Dec 18, 2001 | 12:05 PM
mad skillz's Avatar
New User
Old Dec 18, 2001 | 12:07 PM
25 Year Member
Default Re: Foam vs K+N filter (mad skillz)
this is off of the K+N website, I refuse to believe that comptech would use foam if it sucked so much ***
Old Dec 18, 2001 | 12:14 PM
mad skillz's Avatar
New User
you must like comptech eh?
Old Dec 18, 2001 | 12:15 PM
25 Year Member
no I just think that they aren't morons, they wouldn't want to ruin their rep by using somethign that reduces power. In any case I'm runnign the K+N in my Icebox
