Disbling power antena on 96 integra couple?
How do I disable the power antenna. If makes funny noises when going up or down.
I know I can unplug it, but I'd rather not take all teh lining out of my trunk. Is there a fuse or something I can pull ?
If you pull the inner fender cover off{in the trunk} you can just unplug it. I think that it runs directly off of the radio and dosen't have a seperate fuse. Also, try pulling the antenna all the way out.......straighten any minor bends.....and spray it with WD-40 or P.B. Blaster and wipe with a rag. Manually slide the antenna up and down a few times and then see if it will work better. If not......Just disconnect. Hope this helps>
