Oil pressure gauge hookup on a DOHC ZC?
Old Oct 18, 2004 | 01:42 PM
MugenFlaredCRX's Avatar
Default Oil pressure gauge hookup on a DOHC ZC?
i was wondering how i hook up my oil pressure gauge. does the oil sender on the back of the block just go to the dummy light on the dash board? or does it have more uses? if it just goes to the dummy light then i'll just unplug it and plug in my aftermarket oil gauge.
Old Oct 18, 2004 | 07:57 PM
drdisco69's Avatar
Default Re: Oil pressure gauge hookup on a DOHC ZC? (MugenFlaredCRX)
If by unplug, you mean unscrew and use another sender, yes. The one there is merely a pressure switch, on/off. All it goes to is the gauge cluster light.
Old Nov 19, 2004 | 09:16 AM
dornon13's Avatar
Default Re: Oil pressure gauge hookup on a DOHC ZC? (drdisco69)
does anyone know the thread size for the fitting i need for that hole...its on a d16y8 tho i assume they are the same prolly
Old Nov 19, 2004 | 10:36 AM
drdisco69's Avatar
Default Re: Oil pressure gauge hookup on a DOHC ZC? (dornon13)
1/8" BSPT. 1/8" NPT will work though ok though. Don't tee it at the block!
Old Nov 19, 2004 | 11:49 AM
stealthmode62's Avatar
Please don't use an npt thread. It's not the right one, and I think most of the "don't T off the block" stuff was created by people putting the wrong threads in the block. http://www.tunertoys.com has a fitting with the correct threads, and it will give you two outlets to do whatever you wish with them, or plug them.
Built4Battle
Nov 2, 2011 11:39 AM
EFityo
Feb 17, 2011 04:48 AM
danny_civic97
Mar 12, 2007 01:00 PM
2khb
Mar 30, 2005 03:20 PM
MugenFlaredCRX
Oct 18, 2004 03:17 PM
