Smog Check in Cali .. Test Only
Old Oct 18, 2004 | 11:19 AM
Rocks
Guest
Posts: n/a
Default Smog Check in Cali .. Test Only
My 92 EG needs to get a smog check . My SRS Airbag light is on . Will this cause it to fail?
Old Oct 18, 2004 | 11:21 AM
civtegra_hybrid's Avatar
Default Re: Smog Check in Cali .. Test Only (Rocks)
no way, only if you check eng light is on.
Old Oct 18, 2004 | 11:45 AM
crashN2u's Avatar
Default Re: Smog Check in Cali .. Test Only (civtegra_hybrid)
I believe only if you're going to the ref, that and if it doesn't light at all(if you take out the bulb). Why don't you just call a smog station and find out?
Old Oct 18, 2004 | 11:49 AM
dantastic's Avatar
test only shouldnt fail you for the srs light. the ref will b/c technically its "unsafe" to work on your car. the ref is much more concered about liability. they wont even test your car if you're low on coolant or oil
Mike457
Honda Civic (2001 - 2005)
May 7, 2016 10:05 PM
Blammo300
Dec 7, 2005 04:45 PM
khmaitek
Jun 12, 2005 09:28 AM
SOLO1racer
Jan 26, 2005 10:19 AM
