advance my timing on DOHC ZC
i advance thetiming on my dohc Zc about 1degree. it pulls harder now in lower rpms, better throtle response, but i noticed, that my rpms for each gear are higher now. like 60km in third gear used to be at like 2.5 - 3, now its around 3.5..is that sposed to happen?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vmm »</TD></TR><TR><TD CLASS="quote">i advance thetiming on my dohc Zc about 1degree. it pulls harder now in lower rpms, better throtle response, but i noticed, that my rpms for each gear are higher now. like 60km in third gear used to be at like 2.5 - 3, now its around 3.5..is that sposed to happen?</TD></TR></TABLE>
you are mistaken.
gear ratios and tire size can change your rpm & mph relation, but not changing the timing. its impossible.
you are mistaken.
hmm then y r my revs up morenow? my tires r still the same..i duno wats goin on.. maybe my motor is f*cked or something.. but i can see that i haf to shift gears quicker now...i need another explanation on wts goin on?
. - Darrell
