question about a b24
Old Dec 17, 2001 | 08:17 PM
wu tang's Avatar
Default question about a b24
well i wanna do a motor swap. now the b20 is non vtec. but the b24 is. it's a 2.4 liter with the new i-vtec. so will that work in my crx? what special things will i need for it?
Old Dec 17, 2001 | 08:20 PM
Mugen Dom's Avatar
Default Re: question about a b24 (wu tang)
ull need uh a rsx to put it in maybe it will work in that
oh yah its a K24
[Modified by jdmB18hatch, 5:22 AM 12/18/2001]
[Modified by jdmB18hatch, 5:25 AM 12/18/2001]
Old Dec 17, 2001 | 08:25 PM
wu tang's Avatar
Default Re: question about a b24 (jdmB18hatch)
it should jst drop right in sence its a b series motor. shouldnt it?
Old Dec 17, 2001 | 08:26 PM
EP3_05's Avatar
The new crv motor is a k24 like the new rsx k20(same family of engines). They both spin in the opposite direction making it very difficult to swap. Plus the intake manifold is on the frontside of the motor and the exhaust manifold is towards the firewall. Basically it is really not possible.
Old Dec 17, 2001 | 08:30 PM
wu tang's Avatar
Default Re: question about a b24 (91civic)
oh, i didn't know it was a k series. thanks. but now will the b20 drop right in?
Old Dec 17, 2001 | 08:32 PM
Mugen Dom's Avatar
with a mount kit yes
Old Dec 17, 2001 | 08:35 PM
wu tang's Avatar
what do you feel the best head would be to put on it is? thanks for helping me out people. cause i wouldnt want to do something stupid.
Old Dec 17, 2001 | 08:36 PM
EP3_05's Avatar
I would throw a b16 head on the b20 block. They are pretty cheap these days especially the first gen. JMO but someone may think differently than me.
Old Dec 17, 2001 | 08:39 PM
wu tang's Avatar
well i was thinking maybe a gsr? because it has more higher end power then the b16 head doesnt it?
Old Dec 17, 2001 | 08:43 PM
EP3_05's Avatar
Correct me if I am wrong, but I believe that the b16 head flows a bit better than a gsr head.
Mugen Dom's Avatar
if u want all motor b16a if u want turbo b18c it all depends on teh goal at hand
Old Dec 17, 2001 | 08:44 PM
wu tang's Avatar
so...i think i will put a b16 head on there. but what types od distrubter cap will i need?? cause i know i will be confused on all of that
Old Dec 17, 2001 | 08:45 PM
EP3_05's Avatar
The distributor cap from a 90-91 integra should work. The internals are the same and I believe you just might have to modify the cap just a bit. Again correct me if I am wrong.
Old Dec 17, 2001 | 08:47 PM
wu tang's Avatar
well im gonna take your work over mine..because you seem like you know motre about it. plus do you know of anyone with a 88 si motor?? plus when i get the ls/b16 done...will it pass smog?
Old Dec 17, 2001 | 08:49 PM
EP3_05's Avatar
I don't know if it will pass smog or not. How strict are they in nevada? I passed my jdm ZC here in Pennsylvania, but I don't know about a CRV-tec. And no I don't know of anyone with that motor as of right now. Sorry.
wu tang's Avatar
now..do you got a zc for sell?? can taht drop right in my car...i got a si crx 1988. will it fit right in?
Old Dec 17, 2001 | 08:50 PM
Mugen Dom's Avatar
wut do u need to know about the d16a6?
Old Dec 17, 2001 | 08:51 PM
EP3_05's Avatar
Sorry, the ZC is sold and my b16 is en route to my house. But yes the zc will drop straight in without the aid of a motor mount kit. It is a very easy swap into an Si. Plus it gives a nice boost in hp. But I think for a swap a b16 or b18 or crvtec would be much more rewarding.
Old Dec 17, 2001 | 08:52 PM
wu tang's Avatar
will it drop w/o buying anyithing into a si crx 1988
Old Dec 17, 2001 | 08:55 PM
EP3_05's Avatar
Technically yes, but there are a few things you might want to consider. You might need a new clutch depending on if your current one is worn. Your current transmission will work. You will probably want to invest in either a 89 integra ecu or a ZC ecu to make the most of the ZC. Of course there are the maintainence items like the timing belt, water pump, distributor cap and rotor, spark plugs, and wires. But basically you could drop it in without having to spend too much.
Old Dec 17, 2001 | 09:28 PM
rockout's Avatar
stick with a b-series. no one ever seems happy with their zc's and everyone in reno has b-series parts so it'll be easier to get stuff locally. if you do b20/vtec or ls/vtec make sure and do it right. you definitely don't want to be buying another block later on down the road. mint green 88's are tiiiiight.
Old Dec 17, 2001 | 09:52 PM
One8Hatch's Avatar
New User
Default Re: question about a b24 (rockout)
or if you want cheap hp, you can always slap a homemade turbo kit on the zc
Old Dec 18, 2001 | 07:17 AM
xJ.SLOTHx's Avatar
if you want a lot of displacement you might want to checkout R&D dyno in Gardena California. they can build your 1.8l into a 2.2l and so fourth. or you might want to also check out http://www.jakesracingengines.com as well. but no one said going fast would be cheap...
Old Dec 18, 2001 | 02:03 PM
wu tang's Avatar
Default Re: question about a b24 (One8Hatch)
one8hatch. why you say mint green 88's are tight?? i really do not like zc's. but i'll need to drop somethin in there. and not a si.
Old Dec 18, 2001 | 06:38 PM
CRzex's Avatar
New User
Go B-Series
