cover dash w/ carbon fiber
Old Oct 18, 2004 | 08:31 AM
@irborne's Avatar
Default cover dash w/ carbon fiber
there are numerous cracks on my dash and it's painful to look at; instread of replacing it, i'm thinking about cover it w/ carbon fiber, any thought, guys?
where to buy large sheet of CF, rasin, etc....
Old Oct 18, 2004 | 09:15 AM
Magnaflow's Avatar
Default Re: cover dash w/ carbon fiber (@irborne)
http://www.shopmaninc.com Best prices naywhere
Old Oct 18, 2004 | 11:04 AM
Synapse Motorsport's Avatar
Default Re: cover dash w/ carbon fiber (Magnaflow)
I would reccomend sanding it, filling the dash and smoothing it out so it is perfect before you do the overlay. I would also use vynal ester resin, as it has some uv pertection and also drys clear, and faster than epoxy resin, and is cheeper too.
Just be ready to do alot of sanding, filling with resin, and clearcoating. It takes alot of work, so good luck. Here is a part I did for an audi tt:
Old Oct 18, 2004 | 12:24 PM
TurboJesse
Guest
Posts: n/a
Default Re: cover dash w/ carbon fiber (Synapse Motorsports)
kid you suck at posting pictures
Old Oct 18, 2004 | 12:52 PM
@irborne's Avatar
thanks for the info guys.... keep them coming...
btw! what pattern/grade are you guys using? i saw several on that site.
Synapse Motorsports, look like your picture didnt come out right.
Old Oct 18, 2004 | 01:08 PM
@irborne's Avatar
btw! what's the proper procedure for laying CF ?
Old Oct 18, 2004 | 01:36 PM
USDMforLife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @irborne &raquo;</TD></TR><TR><TD CLASS="quote"> btw! what's the proper procedure for laying CF ?</TD></TR></TABLE>
vaccum bagging is the best thing you can do but expensive
Old Oct 18, 2004 | 03:07 PM
Vaccum bagging is the best, put not neccesary when doing an overlay, because u need to sand the **** out of it anyways. If your using mold contruction for a part, vaccum bagging by far will get you the best results.
Old Oct 18, 2004 | 04:59 PM
turbo gli's Avatar
Default Re: (Synapse Motorsports)
if your dash has a cover over it .. i.e like fake leather or pleather or what ever oem crap .. is ther foam under it .. a small layer kinda like asbestos type or potting foam .. i belive all dashes have it .. skin the dash and then fill the poris foam with bondo or some type of light weight filler .. and then lay the c.f over that . havent done it but a good c.f worker told me that that would be a good route in covering the dash ... but i bet theres other ways
jdmxsi92turbo
Welding / Fabrication
Feb 5, 2011 07:31 PM
DetainedCivic
Mar 2, 2006 11:11 AM
9seccivicsi
Sep 18, 2004 09:03 PM
Houston Hatchback
29
Sep 16, 2004 06:36 AM
20lb.teg
Nov 9, 2002 07:00 PM
