4th gen fog lights
I'm looking for fog lights that will fit in the oem front bumper of a '92 prelude. I've seen a few with what looks to be an oem housing that fits in the cranny next to the front turn signal. If they are oem, are they still produced, available, or any good? If not those, then does anyone have any recommendations on something that will fit? I'm also curious about price, installation and quality of lighting. thanks
Look for the JDM ones, you can pick up a set from places like passwordjdm.com I can't personally say if they are good or not, but I think they look clean and fit the front well
You can still order OEM foglights from honda.. They come as a complete kit including wiring, switch, and lights...
product #112608 http://www.hondaautomotivepart...2.jsp
But they are cheap. $261
No you can NOT order these lights from honda, they no longer make them and are out of stock completely.
You can only buy used.. search ebay, contact JDM engine distributors to try and find them, otherwise there is a LOT of room in the OEM location of the fogs and our cars ARE pre-wired ... read the directions on http://www.hondaautomotiveparts.com for the accessories, there is a write up to install the OEM fogs, just replace it and wire your own switch and splice wires with wahtever brand you want to buy (that is if you decide not to go OEM)
Is the light output from the oem's make them even worth buying?? I have found clear and yellow (yellow's more expensive) JDM lamps, but does anyone know if theres piaa's or some other brand that cost around the same that fit and light better?
They wont fit as clean and stock looking.. have you seen photos of oem??
If not I'll throw one up of my car..
You can get Piaa H3 bulbs .. Yellow are supposed to be better for light in real fog.. I like piaa for more light and bling factor .. but im using autozone GE H3 clear bulbs in them now .. lots more light.
H3 is the standard fog light bulb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yohan »</TD></TR><TR><TD CLASS="quote">They wont fit as clean and stock looking.. have you seen photos of oem??
H3 is the standard fog light bulb.</TD></TR></TABLE>
Pics please, because I have heard people say this, but mines are stock fogs on a '92 Si and they don't look all that different and out of place as the JDM ones.
EDIT: my bad I missed the entry that you were replying too.
