1994 Honda Accord idle problems
Old Oct 18, 2004 | 05:50 AM
LostSoul's Avatar
Default 1994 Honda Accord idle problems
Hi-
I'm trying to figure out what is going on with my 94 Honda Accord 4-door and have yet to get an explanation. When the car is in idle, it will continuously jump from 1000RPM to 2000RPM, but seems to be completely fine when I am in gear and the car is moving. Also, the check engine light came on as I was driving the other night and I haven't touched the car since.
Anyone have any ideas? Or should I just suck it up and take the car to a Honda dealership for repair?
Thanks-
Brian
Old Oct 18, 2004 | 06:11 AM
Desslok's Avatar
Default Re: 1994 Honda Accord idle problems (LostSoul)
Sounds like it could be EGR or IAC valve related. Do a search for those.
Old Oct 18, 2004 | 07:27 AM
khenning's Avatar
Check to see what error code you get from the check engine light. That helps a lot. You probably don't have OBDII since it is older than 96 so I am not sure how you would go about doing that but if you haven't already, invest the $10 for a Haynes manual. They have all the answers and it will be a heck of a lot cheaper than letting the dealership stick it to you.
Old Oct 18, 2004 | 08:55 AM
LostSoul's Avatar
Default Re: 1994 Honda Accord idle problems (96vtec)
I'm hardly a car techie, well not even close. Would it be relatively easy for me (being a novice) to replace the IAC valve?
Modified by LostSoul at 10:27 AM 10/18/2004
Old Oct 18, 2004 | 06:56 PM
PrettyLude's Avatar
yeah, just two 14mm bolts, check and see if the screen is dirty also
emagineitblu
Honda Accord 2016- 2017
Apr 1, 2018 08:00 PM
epichonda91
Jul 18, 2013 11:06 AM
J.STi
Jul 9, 2010 08:30 PM
russ2169
Oct 23, 2009 03:22 AM
Dough_boi
Jul 30, 2009 11:03 AM
