How to remove VSS (vehicle speed sensor) JDM H22A manual
Old Oct 18, 2004 | 05:43 AM
vtec_lude's Avatar
Default How to remove VSS (vehicle speed sensor) JDM H22A manual
Hi how do I remove the VSS from a JDM H22A manual lude? I can get to one of the bolts but the 2nd 1 is obstructed and I can't get a socket on to it...
Thanks for all the help!
Old Oct 18, 2004 | 06:31 AM
Eddiebx's Avatar
use a box wrench
Old Oct 18, 2004 | 07:09 AM
eLUDEnu
Guest
Posts: n/a
Default Re: (Eddiebx)
take off whateveris in the way.
Old Oct 19, 2004 | 05:01 AM
jackstands's Avatar
Default Re: How to remove VSS (vehicle speed sensor) JDM H22A manual (vtec_lude)
Ignore the bolts that are facing away from you. It's the long bolt that is next to them and that is easily accessible, that's what you got to unbolt to get the VSS out.
Old Oct 19, 2004 | 06:38 AM
eLUDEnu
Guest
Posts: n/a
Default Re: How to remove VSS (jackstands)
yes cause there are three bolts on there. The one you want to undo is the one that sits lowest to the trans if that makes any sense to you!
Old Oct 19, 2004 | 08:24 AM
yohan's Avatar
I was thinking it was only 2 bolts, there is a piece on top tha twill come off, dont take it out .. you might loose the little pin that goes inside ...
I assume the air filter is already disconnected, reach on down there and feel for the bolt .. use extensions and a small ratchet, you can get it out ...
if you dont have a helms, buy one now .. the diagrams help a lot.
wtfitzphat
Sep 14, 2009 01:00 PM
Twistedframe
Oct 5, 2007 05:44 PM
gerhard
Dec 7, 2004 03:14 PM
Mercuryc2001
Nov 8, 2004 11:24 AM
