K series potential: k20a EG dynos , stock ECU vs Mugen ECU vs Hondata K-pro
Try to read the whole post
To get HP multiply by 1.3410
Car belongs to Z from Australia.
Here's the car
The car is a k20a EG with DTR fab header using a 4-2-1 header (thanks Danny! ).
The lower line of course is the stock ecu.
Look at the midrange gain with the MUGEN ECU
In this dyno the upper line is the Mugen ECU
then two weeks later,
new dyno in with hondata K-pro tuned+3 inch exhaust + 104 octane fuel
the blue line is k pro vs the mugen ECU dyno
On average I have read that has Dyno Dymanics 27% driveline loss. That really doesn't matter though because reference there are dynos of cars on the same dyno.
For reference, cars that have used the same dyno (actual facility/shop)
> K Series
> 02typeR..............DC5R..........112.2....K20A2 Toda Header, Injen CAI,
> full exhaust
> JDC5R.................DC5R..........107.8....K20A2 Mugen ECU, RM01, Apexi
> Pod
> HighDC5..............DC5R..........101.5.....K20A2 2.25 custom zorst,
> Injen CAI
> bartek.................DC5R..........98.8.....K20A 2 BC III, Apexi short
> ram intake (not full dyno run - cutoff at 7000rpm)
> B Series
> B18
> MPD076...............DC2R...........98.8.....B18CR STOCK
> RedGoesFaster.....DC2R...........98.2.....B18CR STOCK
> Trenty (gohan).....DC2R..........96.5.....B18CR Toda Header, ART Intake,
> stock exhaust
> n.aspirated...........DC2Rjdm......96.3....JDM B18CR STOCK
> Felix (THX90D)......DC2R..........92.8.....B18CR CAI
> booget.................DC2 VtiR......92.2.....B18C 4-1 headers, exhaust,
> CAI
> slowvtec...............DC2 VtiR.....91.1.....B18C 4-1 headers, exhaust,
> CAI, Hondata
> sp00n.b0i .............DC2R..........89.6.....B18CR mods???
> malinG..................DC2R...........89.5.....B1 8CR Adj. Cam gears
> (Hannys)
> ITRay..................DC2R............85.8.....B1 8CR mods???
> OLM-02R.............EG Civic........81.5.....B18C/B16A Mugen 4-2-1, Trust
> Air filter, Adj. cam gears
> DC2spec94..........DC2 Gsi.........73.5.....B18B exhaust, air filter, SAFC
> joneblaze ...........DC2 Gsi.........67.5.....B18B STOCK
> B16
> bizee_1...............ED Civic.......83.8.....B16A, intake, full exhaust,
> chipped ecu
> AUSVTEC.............ED Civic........79.8.....B16A pod filter, exhaust
> vti-11r.................EK Civic........79.2.....B16A2 exhaust, pod
> filter, Toda Flywheel
> Choongas ..........EM1 VTi-R.......76.6.....B16A2 K&N filter
> ONVTEC..............DA9..............76.5.....B16A Camshafts, cam gears,
> exhaust, hi flow cat
> z10.....................EK Civic.........75.5.....B16A2 STOCK
> luzinit..................EK4..............74.5.... .B16A2 air filter
> Civic Si.................???..............74.4.....B16A2 pod filter,
> exhaust
> DarkCivicCoupe...EK VtiR............73.6.....B16A2 STOCK
> Typerlc................EG4 SiR.........57.....B16A JUN chip, (no VTEC)
Just one more note
The reason why we see such performance increase from RSXs with k20a VS Civics with k20a is mainly because of the header design. In the rsx the header geometry is restrictive and doesn;t allow the car to perform to its full potential.
this is the TODA header for k20a (USDM RSX type S )
and this is the DTRfab header 4-2-1 this car is using
I guess lessons learned from B series headers payed off
Here's the car
> K Series
> full exhaust
> Pod
> Injen CAI
> B Series
> B18
> stock exhaust
> CAI
> CAI, Hondata
> (Hannys)
> B16
> chipped ecu
> exhaust
Just one more note
DTR header is looking good. SO how much of a power gain would you get from having the exact same motor and mods in an DC5 and then swapping it to a Civic?
I honestly do not know. My guess is around 20whp because there are 2-3 k20a eg that only with header and k pro are dynojetting around 220whp and I have seen stock RSX k20a dynojetting 180 whp on average without k pro and 200 with it. Tuning can take you a long way though so I am not sure.
Here's a video of the dynorun
http://www.k20a.org/zidyno.mpeg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">Thats not bad numbers around 203whp
it more, the dyno has around 27% loss
</TD></TR></TABLE>it more, the dyno has around 27% loss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonfan »</TD></TR><TR><TD CLASS="quote">sick car, makes me wanna be a k20 in an eg or ek even more
Do it!
Hopefully in a few years I will have a K20 CRX
</TD></TR></TABLE>Do it!
$$$$$$$$$$$$$___$$__________$$$__$$$$_____________ __$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________
I know you guys hate to use the calculator, but if you look at the numbers... this car is gaining almost 40whp with header, k pro , intake and exhaust.. He is using 106 octrane though but still that is a shitload of power. In dynojet terms roughly, he is basically going from 180-220. That is one nice jump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chainsaw »</TD></TR><TR><TD CLASS="quote">nice.
so is the DTR Fab header for sale to the public or is it a custom thing?</TD></TR></TABLE>
It is available for sale...
Here are the prices
http://www.dtr-fab.com/product....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">1/4 times? </TD></TR></TABLE>
The person who owns the car is in australia and that is his first drag racing experience... On full interior, power this power that, around 2200 lbs he pulled a 12.9 with 1.8 sec... I forgot the trap speed...
Also he has the full-race traction bar. The 12.9 was actually with the mugen ECU because in australia Hondata K pro tuning is not like here and the car was not ruunning very good with. We are trying to remotelly help him though
A similar car as far as setup, with same motor and header did a 12.4 (honda tech user name = allmtrallday )
Here are the prices
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zz10xx »</TD></TR><TR><TD CLASS="quote">it was 12.9@105mph 1.9 60ft with BFG drag radial.</TD></TR></TABLE>
nice
nice
extracting power out of a stock K20 is already so cut and dry at this early stage.
im impressived without a doubt.
Restrictive header Gemometry? please do elaboaratE>?
funny thing is that if your speaking of header design engineering etc. the toda header is more correct then the dtr especailly for a tri Y
a tri y on a 180 firing impulse 4 cylinder engine with a firign order of 1-3-4-2 you would pair the cylinders that are 180 degrees out. hence the toda pairing of 1-4 and 3-2
As well as the toda collectors look like they are placed @ the correct header length where the DTR header has them way down the primary tubes. this is fine and will work well as shown above and the dtr will probably work great for some stock applications
But on a well developed high output k series engine the the toda header should shine through as being superior
Dont get me wrong i like the str header and danny is a nice guy not trying to clwon anyones stuff casue it makes good power just trying to prove a point
and the numbers that you were providing 220 with header those numbers were on a tuned k pro
the most i have seen a untuned k put out with i/h/e was 215. something and that was by joe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JerseySiPOS »</TD></TR><TR><TD CLASS="quote">extracting power out of a stock K20 is already so cut and dry at this early stage.
bwahahaahahahaahahahahaha. i was so "impressived" that looking at the K20 gave me a hard on and the inability to freaking SPELL!!! LOL
thats why K-series got me too.
</TD></TR></TABLE>bwahahaahahahaahahahahaha. i was so "impressived" that looking at the K20 gave me a hard on and the inability to freaking SPELL!!! LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 »</TD></TR><TR><TD CLASS="quote"> not trying to clwon anyones stuff casue it makes good power just trying to prove a point
I am sorry it you misunderstood my intetions. Not trying to clown anyone...
i have seen rsx type s with toda heads and headers +toda flash making as much power as an internally stock k20a2 with DTR header +k pro and some mild head porting... There has to be an explanation for this... I think it is the header. You are in the header/collector business, I am not and do not know much about making a header. But when I see excatly same setups being 15-20 whp apart, I put two and two together, that is all..
Does dtr use your collectors? I know the true race header does, and that makes good power too... Hytech, dtrfab and true race do look alike afrer all.
Nikos
Nikos
point 1 true race tubing pack may be the same but thats how it came out i specified the design on that header length dimensions etc.
Toda heads as in a reworked race head or? cams and valvetrain?
No dtr doesn't use our collectors, gotta remember its not the collector itself thats crucial; sure it helps but it is the sizing that counts
There are so many variable out there such as tuning dyno etc on and on it makes it extremly difficult to do back to back comparisons
umm I don't see why you guys are using 104 octane fuel??
any reason for that high octane..?
K series
PAGE TWO OWNAGE
K series
PAGE TWO OWNAGE
