My hat's off to Eagle's oustanding rods *destruction pics*
Old Oct 17, 2004 | 10:09 PM
Brewer's Avatar
Default My hat's off to Eagle's oustanding rods *destruction pics*
NOT MY MOTOR
When a valve dropped at 12,000rpm due to the infamous 3-2 miss-shift everything demolished. The piston is a top of the line forged piece, and as you can see is long gone. The rod, however, is virtually untouched and still measures out totally in spec!
Eagle Rods
Eagle Rods
EDIT: Here is the rest of the motor -
Modified by BrewerHatch at 1:18 PM 10/18/2004
Old Oct 17, 2004 | 10:14 PM
bossman032's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (BrewerHatch)
MAYBE THE PISTON TOOK ALL THE HIT
Old Oct 17, 2004 | 10:16 PM
eg_type_r93's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (bossman032)
not already didnt you just complete the build not to long ago
Brewer's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (eg_type_r93)
NOT MY MOTOR
Old Oct 17, 2004 | 10:18 PM
eddiecut's Avatar
motor set up?
Old Oct 17, 2004 | 10:20 PM
Brewer's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (eddiecut)
~300whp turbo B16A
Old Oct 17, 2004 | 10:26 PM
sporkcrx's Avatar
Old Oct 17, 2004 | 10:31 PM
KlawzOfDeath's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (sporkcrx)
do you know what the person torqued the rod bolts to? and what bearings they were using?
Old Oct 17, 2004 | 10:48 PM
H.A.R.T B18C1EG6's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (KlawzOfDeath)
hahaaha dam... Eagle rods are dam strong
Old Oct 17, 2004 | 10:51 PM
six sigma racing's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (H.A.R.T B18C1EG6)
i wouldn't be to sure to reuse those rod... for the price id replace them and buy a whole new set...then take a chance running them in a full race motor...... just my 2 pennies
Old Oct 17, 2004 | 11:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (DTRFAB)
ya for the price i wouldnt do it either......
Old Oct 18, 2004 | 12:15 AM
@ries's Avatar
OUCH! thats gotta hurt.
Old Oct 18, 2004 | 12:36 AM
OLM-02R's Avatar
dang... for the rods
Old Oct 18, 2004 | 03:04 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (OLM-02R)
Damn, that looked brutal
Was the head toasted as well?
Old Oct 18, 2004 | 03:49 AM
fro5tbite's Avatar
damn those eagle rods didnt even scratch..
sorry about the motor tho
Old Oct 18, 2004 | 04:29 AM
lohatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlawzOfDeath &raquo;</TD></TR><TR><TD CLASS="quote">do you know what the person torqued the rod bolts to? and what bearings they were using?</TD></TR></TABLE>
the rod bearings have been removed, if you are trying to say they look torn up.
Old Oct 18, 2004 | 05:27 AM
Jspectyper's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (lohatch)
dAng
Old Oct 18, 2004 | 05:37 AM
AWDxBOOST's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (Jspectyper)
dear god....
Old Oct 18, 2004 | 06:57 AM
Brewer's Avatar
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (itr_eg)
The head is a total loss, and the sleeves were demolished. The block is salvageable thanks to the blockguard.
Old Oct 18, 2004 | 07:45 AM
Eddiebx's Avatar
hey any clue what size rod bolts those are?
Old Oct 18, 2004 | 08:39 AM
NSTY Z33's Avatar
Default Re: (Eddiebx)
The problem with eagle rods is not the strength, but the rod bolt failing and the cap making a hole in the block.
Old Oct 18, 2004 | 11:20 AM
98itr0448's Avatar
did the same thing in my b18c5. Broke the sleeve all the way to the bottom and found pieces of my piston throughout my motor. The stock rod was still there, although damaged to say the least. The other three spec'd out fine and are all good. I'm putting eagles in my ls/vtec setup, so I'm happy to see they held up!
Old Oct 18, 2004 | 11:21 AM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: My hat's off to Eagle's oustanding rods *destruction pics* (98Itr-0448)
Eagle Rods
Old Oct 18, 2004 | 11:22 AM
vtec69's Avatar
wow i wouldnt expect that to happen with an eagle rod
good ****
Old Oct 18, 2004 | 11:34 AM
The Destroyer's Avatar
Default Re: (CRXDelSol!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDelSol! &raquo;</TD></TR><TR><TD CLASS="quote">The problem with eagle rods is not the strength, but the rod bolt failing and the cap making a hole in the block.</TD></TR></TABLE>
It is installation error, not random failures.
