winter tires?
I allways mount my snow's and race tires on seprate rims so that i only have to pay for mounting once. And so that i can change tires in my garage.
One of the best out there are the Bridgestone Blizzack. Another good one is the Michelin Artic Alpine and the Pilot Alpine.
Allthough i run the Sams Club specials on my car. They work great. They were pretty cheap as well. They are a little noisy, but not anymore so than my Falkens.
A great place to get Snow tires is thru http://www.tirerack.com They sell a winter tire package, they come with steel rims and hubcaps and lugnuts.
Depends what you mean by "good" and "expensive" -- in my book there all good brands of winter tires are expensive (but worth it). I believe a "good" winter tire should:
1) remain pliable at temperatures below freezing
2) handle better on ice
3) handle better in snow
4) do all the things a "good" summer tire does.
I really like the Michelin Pilot Alpin's for the 5th gen prelude but they're getting very hard to find in our stock size. The US' East Coast was hit with quite a snow storm two winters ago (snow almost as high as the car!) and I was out the same morning as the 4WD SUVers (and doing better than the over-confident 2WD SUVers).
Yeah, the performance winter tires like the Pilot Alpin & Bridgestone's LM-22 are great, as long as you don't get significant snow build-up. Any kind of regular driving through snow accumulation on the roads more than an inch or two on the roads, and you need something with the wider spaced tread-blocks like the standard Blizzak, Dunlop, or a Nokian.
I'd definitely recommend getting another set of wheels - makes swapping over so much less of a headache. Being able to swap them yourself in under an hour is a very nice luxury - trying to get an appointment at a tire place right when the snow starts to fly is insane.
And if you need a more capable winter setup, go for a smaller wheel & a narrower tire. It'll cost less, and have much better winter performance.
