what is this on the back of the LS block?
that's the box where the PVC valve goes on the older B18B engines. The newer B18B's had the PVC valve on the valve cover and didn't have that box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">that's the box where the PVC valve goes on the older B18B engines. The newer B18B's had the PVC valve on the valve cover and didn't have that box.</TD></TR></TABLE>
good answer
Since the newer motors recycle the vapors back into the motor, do they suffer performance losses from more sludge inside everything?
good answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I'm pretty sure it's the same operation, they just simplified the mechanics of it.</TD></TR></TABLE>
I think thats right. They basically just changed the location.
So if I have a B18B block with that box on it and I am using it with my vtec head from an 00 GSR how would I set up my aftermarket catch can? Do I need to run the inlet line from the fitting on the block or the fitting on the intake manifold? This is not a pain in the *** hypothetical question it is one that is going into effect in the next few days.
invisible
Mar 13, 2007 10:35 AM
bleedblue94
Apr 6, 2006 08:43 PM
