My Baseline Dyno Results
Here it is, my baseline dyno graph. Notice how rich it is around Vtec engagement (5800rpms) off the charts like 8:1. So pretty much what i learned fomr this is that im not lean an im not detonating
This is the best i dynoed, It actually broke up in vtec for a second as you can see cause like a dumass i added fuel instead of leaning it out. this was the second run. The Tq curve was kinda all over the place too which i thought was weird.
This is all 3 of my runs. overlapped
I made peak power around 8400-8500 rpms. i made peak tq arounf 8k rpms. I had vtec set at 5200 for the 1st run then 5800 for the last. As you can see it needs a good tuning session. Im trying to get to Mainstream this week to play with it. Keep in mind I made NO FPR, Cam gear adjusments an MINOR vafc adjusments. I think with soe real tuning an a few more degrees of timing i can hit 190-195 whp which was my goal. When my ported head gets here i want 210-215
Mods are
GSR block 81.5mm
decked .10 11.5:1 compression
B16 head
M22 cams an valvetrain
AEBS mildly ported intake manifold
ANR header
S2 cam gears
Walbro 255 fuel pump (came in the car)
H22 290cc injectors
B+M adj FPR
Nopi #1 intake
Modified by VtecKiDD at 9:35 PM 10/18/2004
Modified by VtecKiDD at 9:41 PM 10/18/2004
Mods are
GSR block 81.5mm
B16 head
ANR header
S2 cam gears
H22 290cc injectors
B+M adj FPR
Nopi #1 intake
P30s at the time were on a 2 month backorder NATIONWIDE. and Im not a Fan of PCT/CTR pistons, compression is too high with them. I want something a little higher than a JDM ITR with a flat top piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">Dyno SHeet up</TD></TR></TABLE>
where?
where?
EM1B18-R
Aug 3, 2005 10:03 PM
good numbers, but why didn't you use p30 or pct pistons? Just curious.
