switch from auto to manual
Old Oct 17, 2004 | 05:19 PM
NavyHonda95's Avatar
Default switch from auto to manual
i have a '95 honda civic automatic, i hate having the out automatic. i want to get a manual switched into my car, whats the best way going about this? and how much would this cost?
thanks
Old Oct 17, 2004 | 05:45 PM
civictildeath's Avatar
Default Re: switch from auto to manual (NavyHonda05)
well if u got the money buy a new car that is already a stick or have someone else change it it is a headache and requires a ton of patience so if you do it yourself good luck
Old Oct 17, 2004 | 06:10 PM
TurboTagTeam's Avatar
Just buy a manual trans civic... It would be alot easier
Old Oct 17, 2004 | 06:17 PM
Default Re: switch from auto to manual (TurboTagTeam)
you sure, installing is would be pretty tough?
Old Oct 17, 2004 | 06:18 PM
bgoetz's Avatar
I did it to a 04 it is harder than a 95. all toghether it cost me around 2000, but I spent 600 on a aftermarket clutch and flywheel and got the best tranny I could find it is not to hard.
for your car you will need:
tranny with clutch and flywheel
master cyl and slave
clutch pedal and brake pedal
shifter
shift linkage
fill bottle for master
clutch lines (you can get at auto zone)
I think that the engine mounts on the tranny side are different
to get it to start you have to jump the park wires so the car thinks that it is in park
Get a helms manual it is the best thing that I bought
a engine hoist is a good thing to have too
Old Oct 17, 2004 | 06:21 PM
sit220's Avatar
i think you will need dif mount couse they are not the same
but i think u shoud sell that car and get a stick car couse my cousing did that swap and it was a pain in tha *** he paid a shop 1500 to do the job and they took alot of time to get it right ( ithink they dint know auto chasy was diferent )
Old Oct 17, 2004 | 06:27 PM
Default Re: switch from auto to manual (sit220)
is it a good idea to swap???
Old Oct 17, 2004 | 06:32 PM
Built Beast's Avatar
a few of my buddies did it (b16pwrcrx & oneslodx) did for another friend of mine....they said it wasn't that bad, most people are like "just buy a manual car" but they really didn't think it was that hard. My friend bought the HCP kit(I think that is the brand kit) for B series swap into a EG, the Auto to manual mount from them...under the center console, the holes are already there, just need to cut them out(open them) and mount the shifter. Integra/Civic pedals are the same so you can use them and they bolt right in. Just to have to wire the car to make it think it is in Park the whole time. and to get the reverse lights to work, run a wire the the sensor on the tranny and bingo, the reverse lights work.
PM them, they will be happy to help you with the swap. Like I said, they didn't think it was that bad. Easier on civics than accords, they have done both. Good luck in what you choose to do.
Old Oct 22, 2004 | 07:24 AM
civictom's Avatar
Default Re: switch from auto to manual (R33CIVIC)
How much is involved in installing the clutch pedal? Does anybody have some specifics or pictures???
Old Oct 22, 2004 | 08:32 AM
b16pwrcrx's Avatar
Default Re: switch from auto to manual (civictom)
ive done 2 auto to manual swaps, easiest way to do the clutch pedal is take the steering colum out, its pretty easy after that
Old Oct 22, 2004 | 09:12 AM
99eciVic's Avatar
Default Re: switch from auto to manual (b16pwrcrx)
once you have the clutch bolted up, just run the master cylinder through the firewall (the holes should already be there, just covered up with rubber), put the two nuts on from the inside of the car, then just use an oem plug or nut and bolt to attatch the pedal with the cylinder, hope that helps a little bit
good luck, i just got mine done and i love it, so much better then an au-slow-matic
Old Oct 22, 2004 | 12:22 PM
hatchi's Avatar
I've done several of these swaps already and make sure you have all the parts if you are doing it yourself. It will save you the headaches of running around looking for them.
Old Oct 22, 2004 | 12:27 PM
SRCivic97's Avatar
Default Re: switch from auto to manual (hatchi)
I've seen threads like this more often than not, try using the "Search" function next time.
Old Oct 27, 2004 | 06:50 PM
s73's Avatar
s73
New User
the manual brake/clutch peddles is not that hard to install, just take out the driver seat and lay down....
you don't need the whole bracket from the brake/gas peddles.....just switch out the brake peddles.....
Old Oct 27, 2004 | 07:54 PM
hoya_10fintec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictom &raquo;</TD></TR><TR><TD CLASS="quote">How much is involved in installing the clutch pedal?</TD></TR></TABLE>
clutch pedal's not hard at all if you're a small guy..
but the brake pedal and gas pedal is one assembly, so it's REALLY bitch to work on especially when pulling it out..
replacing just the brake pedal was a lot harder than I thought. it was rather easier to replace the brake/gas pedal assembly but you have to drop the steering colum down to pull the brake/gas pedal assembly out/in.
I forget the name of the company but you can get auto-man. mount.
OR
get the "manual tranny (upper) mount bracket" from a Honda dealership and any 92~95 civic/94~00 integra tranny mount(man.) from a junkyard..
either way is good but MAKE SURE you have ALL the parts for the conversion.
if you can't, sell it and get a man. car..
good luck man.
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
thascientist25
Honda Civic (2001 - 2005)
Sep 9, 2007 06:52 PM
BeBe
Oct 7, 2004 07:44 PM
LudeSi-93
Dec 26, 2002 08:04 AM
s0liDyNe
Sep 18, 2002 06:12 PM
