Overheating.......fan kicks on late, help please
Old Oct 17, 2004 | 03:56 PM
JDM R's Avatar
Default Overheating.......fan kicks on late, help please
Sup guys, Ill start things off by telling you what my setup is. 97 hatch. Motor is a 97 jdm type r, oem thermostat (new) oem fan switch, fluidyne radiatior, big end slim fan and spoon radiator cap.
Heres the problem, in traffic or at idle the temp gauge slowly creeps up. And when moving the temp goes back to normal. I know thats due to air passing through the radiator. First thing i did was bleed the system......that didnt help. Then I replaced the thermostat......no help there. After I replaced the thermostat I checked the fan and I noticed the fan would kick on late. The needle is about 75% up when the fan kicks on. I replaced the fan switch and im still having the same problems. I am stumped and i have no idea what the problem is. Any help or ideas are greatly apprieciated. Thanks
Old Oct 17, 2004 | 04:03 PM
CoolJimWhy's Avatar
Default Re: Overheating.......fan kicks on late, help please (JDM R)
I don't know exactly, but I'll try to throw some of my 2 cents in. What I'm thinking is the trigger to hit on the fan is faulty, probabily kicks in late because the higher amount of heat compensates for its faultyness. I know you replaced basically everything related, but its a temperature switch, like a slow reaction therm. I'm not solving the problem, but hopefully this thought process may spark something up there
Oh BTW, I envy your car.....
Jim
Old Oct 17, 2004 | 04:58 PM
JDM R's Avatar
Default Re: Overheating.......fan kicks on late, help please (CoolJimWhy)
thanks dude ill look into that, anyone else?
Old Oct 17, 2004 | 05:31 PM
sinister6's Avatar
is the thermostat an OEM or some aftermarket parts? i have the same problem on stock unit before, changed it to a Mugen and it never pass 45% ever.
btw, the way to bleed/Flush the system. I dont know, I unplug the upper hose and the cap then start the engine, throw in a water hose and keeps the water running into the radiator. after 15 mins, there is a great pile of brown colour build up on the floor..(which looks like sand)
I dont need to measure anything, but with all those build up in my cooling system?? im sure my engine runs happier then ever
Old Oct 17, 2004 | 10:06 PM
JDM R's Avatar
Default Re: (sinister6)
yea thermostat is OEM honda, flushed the coolant a few times since i got the motor. its pretty clean in there
Old Oct 17, 2004 | 10:32 PM
sinister6's Avatar
then an aftermarket thermostat should be purchased??
Im using SARD, 68 degree opening
Old Oct 18, 2004 | 09:51 AM
JDM R's Avatar
yea i think im gonna switch to a mugen thermostat and switch. anyone else?
Old Oct 18, 2004 | 06:44 PM
JDM R's Avatar
Default Re: (JDM R)
TTT
Old Oct 19, 2004 | 09:57 AM
JDM R's Avatar
Default Re: (JDM R)
up
Old Oct 19, 2004 | 10:18 AM
sinister6's Avatar
find out i have type in wrong info. Im using SARD thermostat and Mugen fan switch.
so did you get the parts done yet?
Old Oct 20, 2004 | 09:34 AM
JDM R's Avatar
not yet im a broke ***
Old Oct 20, 2004 | 12:47 PM
92b16si's Avatar
this happen to me once man i changed the relay in the fuse box by the battery in my eg and that fixed it
Old Oct 20, 2004 | 01:07 PM
SniperRCivic's Avatar
yea dude like they stated above try to replace them at the same time. you said that you 1st did the therm. and then the fan switch so theres a chance if the fan switch was fualty that it might have fried the therm. for a 2nd time. since your gonna get new parts get a relay.if the cars over heatin the you must be throwin a check engine light do a code check to see what it might be before you buy. anything. sorry for the long @$$ reply just tryin to help
Old Oct 20, 2004 | 09:45 PM
JDM R's Avatar
Default Re: (92b16si)
cool ill check into the relay
Old Oct 27, 2004 | 09:38 PM
JDM R's Avatar
Default Re: (JDM R)
bump for more ideas
Old Oct 27, 2004 | 11:13 PM
yoej8's Avatar
i had a similar problem on my old 84 civic... mine had a leaky hose which kept it from makin its rounds... i kinda doubt its the hoses... but you could always check up on it
Old Oct 28, 2004 | 08:38 AM
the only other thing i think it could be is have a compression test to see if its flowin good or how many miles are on the car maybe you need a new water pump ??
Old Oct 28, 2004 | 10:08 AM
JDM R's Avatar
Both the hoses and water pump are new. I double checked the hoses and there are no leaks
what would cause the fan to turn on late?
Old Oct 28, 2004 | 10:11 AM
JinDIESEL's Avatar
Default Re: (JDM R)
check the relay first.. if that doesnt do it, check your fan sensor and your thermostat.. they both work to let the fan know to turn on..
Old Oct 28, 2004 | 03:07 PM
when i had that problem the last thing i did was replaced the fan motor and i have nt had a problem since (knock on wood)
Old Nov 4, 2004 | 09:50 AM
JDM R's Avatar
Ok I changed the relay and the fan is still kicks on late. Now what do i do?
Old Nov 4, 2004 | 12:37 PM
JDM R's Avatar
need some more ideas
Old Nov 4, 2004 | 12:39 PM
shifty35's Avatar
I'd bet good money it's your headgasket if you've checked everything else. It's an easy $35 fix if you do it yourself.
Old Nov 4, 2004 | 01:08 PM
JDM R's Avatar
Default Re: (shifty35)
how do i know if my headgasket is blown? Coolant looks good and theres no white smoke coming out the exhaust
Old Nov 4, 2004 | 01:12 PM
jethawk's Avatar
white smoke would more then likely be coming out of your exhaust if it was a blown headgasket.... so you can rule that out..... in my dads camaro he change the fan turn on temp via his hypertech into the ecu.... maybe its changed in yours??? i just got my honda so i dont know much about them... but maybe its that???
