so i got a 92 civic cx
Old Oct 17, 2004 | 01:00 PM
(Civic_Duty)'s Avatar
Default so i got a 92 civic cx
i got a 92 cx and a d16z6 currently in my 88 crx wired up obdo
what do i need to put the z6 in the cx??
will a p28 plug right in? (pinout the same)
is vtec and vtec pressure all i have to run?
i still have all the old1 stuff from when i bought the z6 dizzy,injectors
Old Oct 17, 2004 | 01:06 PM
Sinner's Avatar
3 wires for vtec,
maybe a obd1 wiring harness,
the p28 will plug in,
motor mounts
thats my list, maybe more..
Old Oct 17, 2004 | 01:09 PM
Default Re: (Sinner)
wire harness come with car th cx currently runs
Old Oct 17, 2004 | 01:12 PM
automotive's Avatar
Default Re: (tweakedcrx)
if its a 92 cx it should be prewired for vtec and its all plug and play with d16z6 wire harness
Old Oct 17, 2004 | 02:04 PM
dantastic's Avatar
assuming that you dont have the stock d16z6 harness any more, use the stock CX engine harness, run the 3 vtec wires to the plugs near the pass. side shock tower (92 CX is prewired from the ecu to there). p28 will plug in to the ECU harness in the CX.
Old Oct 17, 2004 | 03:15 PM
Default Re: (dantastic)
do u know what wire i need to tap into at the shock tower
Old Oct 17, 2004 | 03:17 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweakedcrx &raquo;</TD></TR><TR><TD CLASS="quote">do u know what wire i need to tap into at the shock tower
nope, but you can use the search link at the upper right corner of the page. try the hybrid forum. or buy a helms manual and check the wiring diagrams
Old Oct 17, 2004 | 03:22 PM
thanks
Old Oct 19, 2004 | 04:51 PM
what about the 4 wire o2??
rdaggett
Mar 8, 2005 09:09 AM
SLowCrx
Dec 16, 2003 02:27 PM
Doeboy
Oct 14, 2003 11:21 AM
civicracer1993
13
Mar 10, 2003 11:47 AM
fasterthenmost
Sep 20, 2002 04:55 PM
