GSRX ITB Question - Did some one fix the TPS issue yet?
The guys on homemadeturbo.com fabbed a set of GSXR ITB's onto a motor and used the Honda TPS, I was wondering if you figured out a way to use the Susuki TPS yet?
http://www.homemadeturbo.com/t....html
When I did search, it's tells me to try again later, and the posts I can find on google turned up nothing.
yes, something is wrong with the system. All you have to do is get a volt meter and adjust the rotor until you get the required output for idle and wot. There are alot of threads about this so you might wait until you can search again.
And use the archive search.
