Anybody runnin on KYBs made for civics?
Old Oct 17, 2004 | 11:54 AM
N~FaMouSKhMerBoi's Avatar
Default Anybody runnin on KYBs made for civics?
will shocks that'll fit a 98 civic fit a 94-97 integra? thanks guys!
Old Oct 17, 2004 | 12:01 PM
sibanez's Avatar
Default Re: Anybody runnin on KYBs made for civics? (N~FaMouSKhMerBoi)
Yeah, they will, but you have to do a little modifying to the rubber bushing in the rears for them to work, nothing too big.
Old Oct 17, 2004 | 12:03 PM
Default Re: Anybody runnin on KYBs made for civics? (sibanez)
thanks man. anybody else can confirm this?
Old Oct 17, 2004 | 12:14 PM
dFreezy's Avatar
i know that the fronts will definitely fit, although the forks on the rears are smaller on civics than integras. i was pretty certain they wouldnt fit, but the damn search feature isn't working now so i can't confirm...
Old Oct 17, 2004 | 04:07 PM
boosted k20's Avatar
Default Re: Anybody runnin on KYBs made for civics? (dFreezy)
i have Bilstein HD shocks made for 96-00 civic in my 97 teg. i had to modify the rear shocks where it bolts onto the lower control arm. the civic shock is more narrow than the integra's in the rear. u can do what the guy said above: cut some of the metal bushing out so the shock will fit (but this can lead to u melting ur bushings) or u can bend the rear shock where it mount to the lower control arm a little bit. this is what i did. i also had to cut off that nut thats welded onto the shock, cuz after i bent the bracket for the shock, the bolt wouldnt line up to that welded nut. i cut it off with a cutoff wheel and then used a bolt and nut to attach it to the lower control arm
gRim06
Oct 18, 2007 10:11 PM
Jimmy
Suspension & Brakes
Jul 17, 2007 10:15 PM
98GSRDC2
Suspension & Brakes
Feb 22, 2007 02:55 PM
xdavidx
Apr 30, 2004 12:03 AM
rockwilda
May 4, 2003 12:35 AM
