EK Sedan passenger side window install
Old Oct 16, 2004 | 11:37 PM
speedracered's Avatar
Default EK Sedan passenger side window install
My Cousin messed up his moms car, and both passenger windows are shattered (4 door). Does anyone have a write-up on how to replace the windows?
Old Oct 17, 2004 | 12:17 AM
BrownDx's Avatar
Default Re: EK Sedan passenger side window install (speedracered)
It's pretty straight forward.
Manual windows are a breeze.
I've never done power one, but it's pretty much the same.
There are only two bolts (manual windows) on each side of the bottom of the glass that hold it in place. They are number 21 and 22 on the diagram also circled in red.
Put the window all of the way down or maybe 3/4 and you will see the bolts numbered 22 and 21 (circled in red. 10 mm I think). Loosen them and make sure to remove all of the glass and then gently slide the window threw the top of the door. Line it up and hand tighten the bolts hand tight bolts numbered 21 and 22 (circled in red). Make sure the window is lined up properly in the track. You might have to make slight adjustments to bolts numbered 16 (circled in blue) to get it aligned properly. When you have the glass lined up in both the top and the bottom hand tighten the bolts that you had to loosen and slowly roll the window up and see if it is on track, make and necessary adjustments and tighten the bolts the hold the glass in place, but DO NOT OVER TIGHTEN.
Hope this helps.
If you have more questions come back.
Ryan
Old Nov 12, 2007 | 02:00 PM
Charlie Moua's Avatar
Default Re: EK Sedan passenger side window install (BrownDx)
how much do you tighten it by? ....
Also after a while when your windows don't line up as well, could it be that #16 bolt just got loose and out of line? ..... all you would have to do is re-alline it right?
Mattcheww
Feb 10, 2009 11:28 AM
Raf99
Apr 2, 2006 04:50 PM
Devilry
Nov 22, 2004 07:35 PM
jakeiscool
Jul 23, 2004 08:29 PM
photec2
Jan 27, 2004 07:33 AM
