Corner Lights/Dash Lights........TEMPERMENTAL!
Man i hope i spelled that right.......LOL
Anwho, 93 Si. Everything works and runs fine, except when i turn the corner lights on.........sometimes they do, sometimes they don't come on. The headlights come on fine, but the corners and dash lights will stay off. All the other lights work fine on the dash except the gauge lighting itself.
It seems to be more reoccuring in the cold, but i havnt narrowed it down to that yet. I usually have to turn the car off......flicker the headlight switch back and forth about 5 or 6 times, THEN they will start to come on.
Again, I'm new to Honda's (but LOVE em!) And i'm still learning, most of which i've learned from HT
So please help!
So please help!
you know i had the same problem so what i ended up doing was buying some white face gauges and taking out all the corner light bulbs out and called it a day but if you can figure it out let me know i want to know also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">sounds like a bad headlight/turnsignal combo switch</TD></TR></TABLE>
So do you mean tearing apart the steering column "thing" or just checking all the wiring under the hood?
kmf0211
Sep 3, 2004 11:17 PM
