WHAT IS THE GAS SMELL 24/7 NEED HELP?
Old Oct 16, 2004 | 10:14 PM
POWERINTEGRA's Avatar
Default WHAT IS THE GAS SMELL 24/7 NEED HELP?
hey guys I just completed a turbo full built and I'm breaking the motor in so far I got 500 miles on it. But since day one I feel this like gas fumes. i already check all connection etc and I see no leaks. I have no idea where is coming from and is getting annoying anybody got the same problem? how did you fix it or it is just the new motor suppose to be like that for a couple of miles?
Old Oct 16, 2004 | 10:21 PM
SpoolnG2's Avatar
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (POWERINTEGRA)
do u have a regular cat? or a testpipe / gutted cat ?
Old Oct 16, 2004 | 10:39 PM
m R g S r's Avatar
I don't think it's that, because mine was the same with a cat, and without. Are you talking about inside the cabin? I think it may be because of an open valve cover vent. . .
Old Oct 16, 2004 | 10:40 PM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">do u have a regular cat? or a testpipe / gutted cat ?</TD></TR></TABLE>
regular cat stock one could this be the reason???
Old Oct 16, 2004 | 10:44 PM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it's that, because mine was the same with a cat, and without. Are you talking about inside the cabin? I think it may be because of an open valve cover vent. . . </TD></TR></TABLE>
yea is when I'm inside and driving around sometimes I get a headache out of this **** when driving for a couple of hours not good I even turn the car on and try to go all over the engine to see if I can feel where the smell is coming from. I run the car and I smell the ac vents nothing! and again I'm left with the WTF.. trying to figure it out
Old Oct 16, 2004 | 10:50 PM
Boltz's Avatar
it has to be leaking fuel, recheck everything over and over
Old Oct 16, 2004 | 10:52 PM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">it has to be leaking fuel, recheck everything over and over</TD></TR></TABLE>
any ideas possible places to check?
Old Oct 17, 2004 | 04:55 AM
Boostage's Avatar
open dumptube maybe? :shrugs:
Old Oct 17, 2004 | 04:58 AM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POWERINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">any ideas possible places to check?</TD></TR></TABLE>
Any place you have a connection on your fuel line. Check your injector seals, lines coming in/going out of your fuel rail.
Old Oct 17, 2004 | 07:58 AM
Dr Pooface's Avatar
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (IslandSi)
Wiggle your injectors a bit. My fuel rail cam loose and injector #4 was spraying a fine mist of fuel al over my engine bay when it got shook.
Old Oct 17, 2004 | 08:09 AM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Wiggle your injectors a bit. My fuel rail cam loose and injector #4 was spraying a fine mist of fuel al over my engine bay when it got shook.</TD></TR></TABLE>
Thanks for all the help guys I will go over everything again to see if I can find this damn leak!
Keep the sujections coming they help thanks
Old Oct 17, 2004 | 08:36 AM
f22b2tdave's Avatar
could it be just from running rich? i know i can smell fumes when im driving all the time but i also have no interior....
Old Oct 17, 2004 | 08:41 AM
Boosted2K's Avatar
If it only does it when driving, the injector seals could be leaking under load, when fuel pressure rises
Old Oct 17, 2004 | 10:22 AM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave &raquo;</TD></TR><TR><TD CLASS="quote">could it be just from running rich? i know i can smell fumes when im driving all the time but i also have no interior....</TD></TR></TABLE>
ummm I only got the 2 front seats do you have the same problem?
Old Oct 17, 2004 | 10:30 AM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (Boosted2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted2K &raquo;</TD></TR><TR><TD CLASS="quote">If it only does it when driving, the injector seals could be leaking under load, when fuel pressure rises
as soon as I turn the car on I can feel it
Old Oct 17, 2004 | 11:05 AM
gunmetalcivic's Avatar
ive had the same problem for over a year. everytime i have had it checked out, nobody could find a solution. bump for a solution.
Old Oct 17, 2004 | 11:08 AM
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (gunmetalcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunmetalcivic &raquo;</TD></TR><TR><TD CLASS="quote">ive had the same problem for over a year. everytime i have had it checked out, nobody could find a solution. bump for a solution.</TD></TR></TABLE>
Yup I hope somebody knows where is coming from!
Old Oct 17, 2004 | 12:36 PM
eg6T's Avatar
i forgot what they are called but buy one of those "detectors" that detect gas.you run the "detector" along where gas flows,the stronger the scent the louder the beep,the louder the beep and you found the problem...just ask a store about this and they should know
Old Oct 17, 2004 | 12:39 PM
Frozen E's Avatar
H-T White Ops
Default Re: WHAT IS THE GAS SMELL 24/7 NEED HELP? (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">i forgot what they are called but buy one of those "detectors" that detect gas.you run the "detector" along where gas flows,the stronger the scent the louder the beep,the louder the beep and you found the problem...just ask a store about this and they should know</TD></TR></TABLE>
Uhmmm, he's talking gasoline. Not natural gas as in your home furnace.
Old Oct 17, 2004 | 01:40 PM
eg6T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
Uhmmm, he's talking gasoline. Not natural gas as in your home furnace.</TD></TR></TABLE>
i kinda figured gasoline because this is a car website...not home-tech.com
Old Oct 17, 2004 | 02:12 PM
Frozen E's Avatar
H-T White Ops
Then why are you suggesting that he use a natural gas/LPG detector?
Old Oct 17, 2004 | 02:51 PM
GOLDBERG's Avatar
Default Re: (IslandSi)
dont drive over flares, LOL
Old Oct 17, 2004 | 03:49 PM
eg6T's Avatar
Default Re: (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Then why are you suggesting that he use a natural gas/LPG detector?</TD></TR></TABLE>
that is not what im talking about..there is one made for cars to detect gasoline leaks
Old Oct 17, 2004 | 04:04 PM
Frozen E's Avatar
H-T White Ops
Default Re: (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">that is not what im talking about..there is one made for cars to detect gasoline leaks</TD></TR></TABLE>
Show me a link to one.
I wasn't aware that they made one for gasoline. If you can show me, then I stand corrected and apoligize. Otherwise.....Ban all '04 members.
Old Oct 17, 2004 | 04:50 PM
honda13typer's Avatar
i had that problem before it made my car smell like gas. the first time i drove it made my eyes water in my case i think it was a leak at my manifold i dont know exactly where but when i retightened everything the smell went away.
