p72 question
Old Oct 16, 2004 | 09:15 PM
PreludePhill's Avatar
Default p72 question
Does anyone know how to control the IAB point on a p72 with a RPM switch?
Old Oct 16, 2004 | 09:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: p72 question (N2oH22)
you need an rpm activated switch to deliver 12 volts to the little solenoid under the intake. put the 12 volts out of the switch to one of the wires off of the iab then ground the other. but if you have a p72 why not wire it up correctly?
Old Oct 17, 2004 | 06:42 AM
i dont know all that much about ecus , i was just trying to do my homework before i went with hondata and came across a thread were people were discussing how the rpm switch would solve the IAB problem.Whicj solenoid under the intake is it?can you be a little more specific?Thanks for the help
Old Oct 17, 2004 | 07:00 AM
v4lu3s's Avatar
RTFM
if you use a p72 it controls the iab, if you use some other ecu you can use the rpm switch.
Old Oct 17, 2004 | 08:05 AM
Mr. Badwrench
Default Re: (N2oH22)
there is a little soleniod under the intake. near that vacuum canister. it has a 2 wire hook up. thats the best i can explain it.
jdm inc
Engine Management and Tuning
May 14, 2009 11:33 AM
PreludePhill
Oct 17, 2004 01:30 PM
another_crx
Audio / Security / Video
Jan 3, 2004 12:35 AM
honda_joe
Jun 12, 2003 10:09 PM
