JDM engines for sale B16/B20
I have a few engines for sale
The first is JDM B20 longblocks. They are all 97+ with low mileage. All compression checked. This includes the block, head, intake manifold, injectors, wire harness, fuel rail. It does not include distributor, might not include throttle body. I cant guarentee that part unfortunately. It will come with everything else though. I sell them for $1050. This is perfect for a B20 vtec, or just to replace your aging ls motor. Startup warranty.
I also have JDM automatic 88-91 B16A SIRI motors for sale. So you know they weren't run to the ground. The first is the longblock. This will include block, head, injectors, throttle body, alternator, may come with AC and power steering pump, and exhaust manifold. No distributor. All compression checked. Startup warranty. $500
I also can get JDM B16A SIRI motor/trans/ecu setup. This will include everything the longblock has, plus distributor, manual trans, and a manual pwo or pr3 ecu. It will be compression checked as well. Startup warranty. $975
GZR4DR
Nov 20, 2001 12:04 AM
