Honda S2000 Honda S2000
switching between ems and stock ecu...
Old Oct 16, 2004 | 08:14 PM
SimbaDogg's Avatar
Default switching between ems and stock ecu...
i know w/ the newer honda ecu's they have the built in immobilizars...my question is if i had the ems, and i wanted to switch back to the stock ecu...lets just say if i needed to smog it, would i have to go to the dealer to get the immobilizar code or anything? or could i just switch back n' forth as i pleased?
Old Oct 17, 2004 | 12:18 AM
ATF Kuk's Avatar
Default Re: switching between ems and stock ecu... (SimbaDogg)
back and forth as pleased.
Old Oct 19, 2004 | 09:48 PM
evil vapor's Avatar
Default Re: switching between ems and stock ecu... (ATF Kuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">back and forth as pleased.</TD></TR></TABLE>
however, if you have the wideband plugged in, you'll need to switch back and forth the wiring and o2 sensors if you don't have 2 ports on your header or don't have both the stock ecu and wideband installed.
Weel
Engine Management and Tuning
Nov 30, 2009 09:10 AM
dc4life20
Honda Civic (2006 - 2015)
Oct 1, 2008 07:42 AM
b16greenmachine
15
Mar 7, 2006 05:10 PM
cityofcaterpillars
Jan 20, 2004 01:05 PM
1.8T_EG
Apr 22, 2003 04:22 PM
