SRP PISTONS---------------NEW IN BOX------------B SERIES-----------STD BORE
Old Oct 16, 2004 | 07:58 PM
PyroProblem's Avatar
Default SRP PISTONS---------------NEW IN BOX------------B SERIES-----------STD BORE
These pistons were originally bought for an Integra LS and yield 10.5:1 compression with stock heads . Milled heads or a thinner headgasket will increase compression just like thicker headgaskets will lower compression...
VTEC engines will also yield higher compression. Approximately +.3 w/B16 head and +.5 with a GSR head...
The part # is 149220. You can get the specs from the SRP/JE site.These are 3.189" or 81.00mm bore size.These are still wrapped in plastic and come with wristpins,locks,and hone/assembly instructions...
http://www.jepistons.com/pdf/2...a.pdf
These would be good for a low boost or nitrous engine being the compression isnt too high.
$350 shipped to the lower 48.
ill post pics soon as I borrow a digicam.
Old Oct 16, 2004 | 08:32 PM
Default Re: SRP PISTONS---------------NEW IN BOX------------B SERIES-----------STD BORE (PyroProblem)
up
Old Oct 17, 2004 | 05:34 AM
bump
Old Oct 17, 2004 | 11:33 AM
Im paying for shipping!!!
$350 shipped to your door...
Use these w/ a gsr head and you have 11.2:1 compression.
Brand new in box people!
Old Oct 17, 2004 | 03:30 PM
up up up
NSfit
Aug 30, 2006 10:56 PM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
Propulsion
Nov 24, 2003 09:16 AM
K20 EG
Jun 17, 2003 11:26 AM
